    I have the 3A with reverse switch but I order one of these below at 10A to test. I would like to link some sort of LCD RPM display onto it .. guess thats for later.
    http://www.ebay.co.uk/itm/12V-40V-10...4AAOSwuAVWxZvG
    Features:
    Control the speed of a DC motor with this controller.
    High efficiency, high torque, low heat generating.
    With reverse polarity protection, high current protection.
    Working Voltage: DC 12V - DC 40V.
    Control Power:0.01 - 400W.
    Static Current:0.02 A ( Standby ).
    PWM Duty Cycle:10% -100%.
    PWM Frequency:13 KHz.
    Material: Plastic, metal.
    Size:6cm x 7.5cm x 2.8cm
    Weight: 70g
    Ralph Waldo Emerson
    That unit is for DC motors, I thought you had steppers !
    I thought it would be ok ?
    Ralph Waldo Emerson
    Quote Originally Posted by Fivetide View Post
    Nope, you need a stepper driver.
    It's perfectly possible to drive the step/dir signals into multiple drivers - probably preferable to driving potentially unmatched motors in parallel (and offers a choice of multiple supplies if the load becomes an issue), but its a cost balance for your solution.
    FWIW - the motors you spec'd - 2A per phase, I guess 2 phase - that's potentially 4A per motor holding current, so you have to be very aware of driving these in parallel.
    Speed and direction control are then determined by the state of the dir signal (CW or CCW) and the frequency of the Step line. You could knock up a speed controller using an Arduino Uno or similar and a few lines of C code, and for relatively little extra cost have a full digital control set-up. Happy to give you more info if you want.
  5. #15
    In my mind its a DC motor with the ability to do stepping ? But I don't need the stop start precision of the step. I just want a small DC motor to turn at below 109 RPM. Hence why I thought a regular DC pulse regulator would just spin it in one direction..
    Ralph Waldo Emerson
  6. #16
    It's a motor where energising multiple windings sequentially results in movement, the stepper driver deals with this, just applying DC or even PWM DC will not run a stepper motor, try it ;-)
    Having control of precise steps allows you to use a frequency generator to create a precise RPM
    You could just use conventional DC motors with a PWM driver but you will find you have some variation of speed with identical motors driven from a common supply.
  7. #17
    DAMN ! I just want a analogue driver/supply turning all three motors at (approximately) the same speed in a single direction lol
    Right then.. 3 of those stepper motor controllers that are all wired to a big pot ? ( I have a box full of big to little Pots )
    Plus about 5 shelves of laptop power supplies of every variant I can name !!
    I will do this ... it wont bloody beat me ..!! :)
    Ralph Waldo Emerson
  8. #18
  9. #19
    Clive - Nail - On Head!
    - Nick
  10. #20
    AHA ! Clive awesome.. just seen the picture on the listing ..thanks mate as always .. going to go with that setup and play around :)
    Ralph Waldo Emerson
  1. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  2. FOR SALE: Nema 34 12Nm stepper motor
    By dsc in forum Items For Sale
    Last Post: 08-05-2014, 01:14 PM
  3. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  4. FOR SALE: Nema 23 4Nm Stepper Motor
    By Shinobiwan in forum Items For Sale
    Last Post: 07-02-2013, 02:15 PM
  5. common wire on stepper motor question
    By progomez in forum Motor Drivers & Controllers
    Last Post: 27-10-2009, 11:56 PM
