Thread: Old Man Learning CNC (OMLCNC)
02-12-2016 #2
02-12-2016 #3
I took the OPs rule one as 'don't spend any money on bits until the design is ready, research done, etc (rather than do it cheaply). Otherwise money wasted on poor choices . . . And no one including Yorkshiremen like to waste it'
Either way no matter, good luck with it. Perfectly possible to build a machine to do what you want. Trick is not to let machine building become the hobby.Last edited by routercnc; 02-12-2016 at 11:20 PM.
02-12-2016 #4
03-12-2016 #5
I see you like to cut dovetails. Have a look through this thread posted by Gerry:
http://www.mycncuk.com/threads/7688-...ovetail-joints
03-12-2016 #6
Thanks for that, I am way off the software side of things yet, but glad someone has already done the work for me.
On length of work, I did this credenza and nest for someone and put dovetails on the end of the top (8 feet long) by clamping the Leigh dovetail jig onto the workpiece and using the router verticaly.
If you see what I mean?
But dont think a CNC could do that, well I havent alowed for it in my design. I suppose a rotating spindle thru 90 degrees on anther axis would do it.
03-12-2016 #7
You don't have to -
http://www.tailmaker.net/
NEW MEMBER: On a steep learning curve
By Laurie in forum New Member IntroductionsReplies: 14Last Post: 01-09-2016, 06:57 AM -
Training / Self learning
By manofgresley in forum Programmers CornerReplies: 3Last Post: 27-02-2014, 01:25 PM -
A learning process
By cropwell in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 21-02-2013, 07:38 PM -
NEW MEMBER: Learning with MYCNCUK
By Goran in forum New Member IntroductionsReplies: 1Last Post: 10-12-2010, 06:08 PM -
NEW MEMBER: Old timer, still learning, Virginia, USA
By GerryR in forum New Member IntroductionsReplies: 1Last Post: 13-10-2010, 10:41 PM
