    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    hi
    what speed can i expect from a wood router running 3nm nema 23 steppers on 3 axis, using the diycnc sytem 3+ board, 2 amp per phase
    24 volt power supply , i can only get about 80mm per min in mach 3 painfully slow
    :feedback:
    More info needed.
    What screws and pitch, what microstepping selected ?
    John S -
  3. Microstepping resolution? lead of the screw? or motor RPM? Any gearing or direct drive?
    Type of screw Lead or ball?
    Quote Originally Posted by jonm View Post
    hi
    jonm's Avatar
    hi
    1/8 step, 3mm pitch one start trapezioid screw, direct drive
  5. That is very slow, you should get far better speed than that.
    Is this while cutting or rapid moves?
    hi
    jonm's Avatar
    hi
    just got the router going have a pen fixed to the z so just drawing with g code , as the z axis travels along the steppers pitch ( as in sound) gets higher every two or three seconds
    That sounds like acceleration could be way way way too low - if the pitch gets higher every so often, then it's probably ramping up.
  8. I would expect those steppers, even on 24v, to handle 2000 full steps/sec easily, thats 10rps, 600rpm or 1800mm/min with little load...
    80mm/min = 26rpm = 0.43rps, 86 full steps/sec
    have you told MACH3 you are using 1/8 step?
    It does suggest your MACH3 settings are wrong...
    Just about to say the same thing....
    Take a look at the attached image which are the MACH3 motor tuning settings for my router and let us know what figures you have, don't use these settings as they will be incorrect for your machine.
Name:	Mach3 motor settings1.jpg
    jonm's Avatar
    hi irving
    i have the "steps per " in mach set to 533.3
    200 X 8 = 1600 divided by the screw pitch which is 3mm = 533.3
    maybe i am missing something here
    resolution seems good i drew a 300mm diam circle and measured it to exactly 300mm
    but the speed is very slow
  1. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  2. Machine Slow on Curves
    By swisscheese in forum Computer Software
    Last Post: 12-04-2014, 12:49 AM
  3. HSM Advisor - High Speed Machining feed & speed calculator
    By magicniner in forum CAD & CAM Software
    Last Post: 20-01-2014, 12:57 PM
  4. Help! Steppers losing steps and making a racket under slow feed..
    By fasteddy in forum Stepper & Servo Motors
    Last Post: 06-08-2011, 03:03 PM
  5. Forum Slow
    By pcstru in forum General Discussion
    Last Post: 27-01-2011, 03:54 PM
