Thread: Cheap large Routers
Well according to the listing, the net weight is 1500kg.
Looking at the photos, to me the metal doesn't look that thick, so at most I'd guess the basic metal work is somewhere around 1000kg. Having just had a quick look at bulk steel costs, the price guides I can find are in the region of 3-500USD per tonne/ton.
As you mention, the big problem is handling the large sections. If you have the capabilities, and buy enough steel to get it at near market prices, the cost of building multiples of this size of machine is far less than what most people would think. Once you've worked out any teething issues with the manufacturing process, it's as simple as cut, weld, paint, assemble.
Plus if you don't have to worry too much about support, that's part of the cost you can greatly reduce.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
26-03-2017 #2
I've converted similair chinese machine and the boxsection was mere 2mm and felt like tin can. However the Frame rails which rails and R&P were mounted on was Cast steel which was machined. It was thin brittle nasty shity casting which snapped if you looked at it funny. Couldn't remove bolt without it stripped threads.
The machined surfaces were so badly machined may has well not bothered. The bed supports which spanned between castings were made from U section and not very strong or straight.
All drilled holes looked like they'd been done by blind man who'd had 10 pints.!! . . . . Z axis was joke and it's now door stop.!!
Yes they are cheap but they need plenty of fetteling IMO which is beyond most people. The electrics are mostly junk and to have reliable machine will at some point need replacing or upgrading so not saving anything there really. This just leaves the main components like linear rails R&P.
I'm with MC in that cost of steel is small in the grand scheme and far better frame could be made for not lot of money. While It's not possible to build same machine cheaper but certainly is possible for DIY builder to build one better for same money.
26-03-2017 #3
Here you go lads have look under her skirt and see exactly what I mean poor workman ship and that looks lot better than others I've seen and the one I converted.!!
http://www.mycncuk.com/threads/10802...0127#post90127
26-03-2017 #4
27-03-2017 #5
3D Models For CNC Routers
By oymacarvings in forum Classified Ads, Buy, Sell & SwapReplies: 0Last Post: 06-10-2015, 08:54 PM -
RFQ: LARGE CNC job - need help
By ChristoT in forum Projects, Jobs & RequestsReplies: 0Last Post: 18-10-2014, 01:48 AM -
CNC routers production in EU
By sw_eng in forum Manufacturer NewsReplies: 0Last Post: 06-02-2014, 10:40 AM -
Transporting a large CNC
By gavztheouch in forum General DiscussionReplies: 9Last Post: 02-11-2013, 05:09 PM -
Differences between routers ?
By John S in forum General DiscussionReplies: 3Last Post: 25-09-2011, 12:13 PM
