    Hi George,
    I wouldn't use the e-stop system to kill the mains power to the VFD, at least not immediately like that. I don't think they like being turned off while the spindle spools down. Instead install a 3 second (say) delay circuit, or leave it connected normally and use the run/stop signal terminals on the VFD control panel to turn it off.
    Hi mate,
    Thanks for the tip. That output on the pnoz is on a delay. Variable from around 5s to a minute iirc.
    Regards
    George
    Sent from my EVA-L09 using Tapatalk
    Quote Originally Posted by GeorgeW21 View Post
    Hi mate,
    Regards
    George
    Apologies George skimmed the dwg quickly. In that case no problem. Those pnoz units are pricey but have nice features.
    Yeah I know, I was pretty shocked when I looked online and saw the retail price . Not having used anything like that before I was a bit worried I wouldn't be able to figure it out, but after a few hours of head scratching with the data sheet I managed to get it figured out. Cheers for taking the time to look over the wiring. Much appreciated.
    Regards
    George
    My first reaction is that 36V is a bit on the low side for a machine of this size. Something nearer 65V with drivers and appropriate motors to match would give much better performance.
    Hi All,
    Can't believe its over a year since I updated this. I got the opportunity to move the the US with work so the CNC had to go on the back burner for a bit.
    Neale - Good shout with the power supply being on the low side. I bought that stepper kit before really knowing anything so its probably not what I would go for ir I was buying again. I'm planning to get it up and running with the power supplies I have but will probably look into putting a larger one in.
    The mechanical design has gone through a number of changes and fluctuating goals but I've now got my mechanical design to a point where I am generally happy with it. Losing access to a workshop or garage has meant the size of the machine has needed to drop quite a bit. I've just recieved the 80/20 extrusion for the chassis and the aluminium plate has mostly arrived for the X and Y axies. This has all come as remnants and offcuts from eBay.
Name:	progress 2018-06-30.PNG
    Here's the controller mainly wired up testing with the little machine I scrounged.
    George
    I see you are running 2.7 linuxcnc is now on 2.7.14 so might be a good idea to update the version. Good luck with the build.
    Progress has been pretty slow but still chipping away.
    CAD now looks like this:
    A few pictures of the build so far:
  2. Beginner Moving Gantry Build? Read This!
    By Tenson in forum Gantry/Router Machines & Building
    Last Post: 23-05-2018, 05:30 PM
  3. Small Fixed Gantry Router Spec and Build
    By shaunrod in forum Gantry/Router Machines & Building
    Last Post: 29-07-2016, 06:55 PM
  4. First build - Mid-scale gantry router design
    By Ellis in forum Gantry/Router Machines & Building
    Last Post: 20-05-2015, 11:43 PM
  5. Vertical moving gantry????
    By Ross77 in forum Gantry/Router Machines & Building
    Last Post: 03-06-2009, 08:34 PM
