I read on the info sheet on these drivers that the normal temperature of a stepper is 80 -90C so quite hot and definately not warm to the touch as others have said.
peter
05-11-2009 #2Visit Us: www.automationshop.co.uk
05-11-2009 #3
I have a strange notion that they get hotter as the load increases. I could be wrong but I seem to remember mine get hot when I put in a fat ripper and cut uphill through steel. Usually I'm an 8mm dowhill in aluminium sort bloke and my motors run lukewarm.
You'd think it would be the same regardless of loading but I'm starting to wonder if stepper motors might be a black art :naughty:
Whatever, I have the motors, I have the drives, I have fat wires and trunking. If the shrinkwrap arrives tomorrow I will wire them up over the weekend then report back
08-11-2009 #4
I suppose a sane person would have tried one motor and driver for the smoke test, but not me, all three on one turn of the switch
Aren't I lucky it passed
Bad luck, I've found out how to add movies
Had to take a movie in case it went horribly wrong :naughty:Last edited by Robin Hewitt; 16-01-2010 at 12:55 PM. Reason: Movie added
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
What voltage for stepper drive?
By Davek0974 in forum Plasma Table MachinesReplies: 1Last Post: 22-01-2014, 10:49 PM -
best stepper driver???????
By Ross77 in forum Motor Drivers & ControllersReplies: 37Last Post: 21-04-2013, 05:05 PM -
Which stepper driver
By Colin Barron in forum Motor Drivers & ControllersReplies: 0Last Post: 25-09-2010, 08:33 PM -
High voltage stepper drivers?
By ZeroCount in forum Motor Drivers & ControllersReplies: 5Last Post: 26-02-2009, 12:07 PM
