    More parts per sheet, some small parts are made from that same sheet, less tools to stock, less tool changers.
    But I could get away with a 3mm cutter on that part without an extra tool change, I've done a finish pass on some 10mm acrylic with the same 2mm cutter to give a clean cut in the past.
    Only really any good doing full clean up passes on new cutters or soft material other wise you still get cut lines.
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    That latest photo looks more like a flex/resonance/chatter problem, which is much harder to address.
    First option would be a dial indicator mounted on the cutting area, with the needle against the spindle/cutter, and see if there is much movement when you pull/push the cutter.
    Quote Originally Posted by Dean jeffery View Post
    Yes, more parts but also greater risk for tool deflection if you are using 2mm cutters.
    But we are discussing soft material here... aren't we?
    Also, the full pass cleaning I normally make is just shaving off about 0.1mm. That gives very good results, even if the cutter is not brand new.
  1. Buying plastics
    By DarrenGrant in forum Marketplace Discussion
    Last Post: 15-05-2015, 12:02 PM
  2. Soft Start Advice
    By GTJim in forum General Electronics
    Last Post: 15-01-2015, 08:47 AM
  3. Plastics for machining?
    By Washout in forum Machine Discussion
    Last Post: 22-04-2014, 11:27 AM
  4. RFQ: Panels cut from soft plywood
    By Rockeyes in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 04:38 AM
  5. Machining plastics
    By Web Goblin in forum General Discussion
    Last Post: 03-11-2011, 08:38 AM
