Thread: Hi. Heres my work
I did the job start to finish using some edgecam and some online programming.
Using 3 axis hardinge 1000 at work.
It was a big lump! Over 100mm thick so took a while to get it cut out.
I used about 30 different types of tools for this job.
I use feeds and speeds i have learnt from experience and up to 6000rpm.
Supporting it wasnt easy and i bolted it to some paralells from undernearth.
Took me 55 hours.Last edited by Ukmiller; 13-05-2017 at 11:48 PM.
14-05-2017 #2
14-05-2017 #3
From memory i used 80mm face tool and long series drills to create a way to mount to paralells.
Then a long 10mm 3 flute to cut off excess material.
Then roughed out with 80 and 50 facemills.
Then various sized end mills and ballnose to achieve shapes. Then many different drills and taps and finally long series tools to do the top angled fine pitch sensor hole.
The item was for atomic testing agency
Work hold down
By gorbo in forum Woodwork DiscussionReplies: 16Last Post: 27-03-2020, 09:15 AM -
4th Axis Work Holding For Rectangular Work
By magicniner in forum Workshop & EquipmentReplies: 1Last Post: 20-10-2019, 03:02 AM -
NEW MEMBER: Heres me - a Total Novice
By CrazeUK in forum New Member IntroductionsReplies: 1Last Post: 14-03-2017, 03:47 AM -
Guitar CNC work
By Guitars in forum Woodwork DiscussionReplies: 2Last Post: 02-12-2016, 10:50 AM -
WANTED: Frame work
By D-man in forum Items WantedReplies: 3Last Post: 30-12-2011, 09:03 PM
