  1. Quote Originally Posted by Mad Professor View Post
    This board is ment to be rated upto 36vdc, So I tried using my 36vdc 10A PSU.
    I set the board to it's lowest current setting on the DIP switches to make sure I did not burn out or over heat my stepper motor, I am only testing X-Axis atm.
    Powered up the board, and all the lights and the fan came on, Turned it all off and, when I next turned it back on, I was greated with a nice pop / bang, with sparks, and blue / white smoke.
    Part of the Z-Axis TB6560AHQ had exploded, Oh Joy.
    I have since looked at some of the datasheet for the Absolute Maximum Rating.
    L7812CV - 35 Volts Absolute Maximum Rating.
    L7805CV - 35 Volts Absolute Maximum Rating.
    TB6560AHQ - 40 Volts Absolute Maximum Rating.
    I will post a pic of the poor TB6560AHQ chip once I have uploaded it to my site.
    Can you turn down the power supply? Mine goes down to 32 and up to 40v. it could be that back-emf from the motor had damaged the chip by spiking the supply - I'd limit that board to a 30v supply if it has regulators on-board unless they have an additional dropping zener diode in series. On my board you can see spikes of 65v on deceleration, so I have a snubber (basically a 36v zener and a low ohm resistor) across the supply. Another solution, shown in the attached schematic uses a transistor to the same effect...
  1. Replies: 1
  2. 4 Axis TB6560 CNC Driver For NEMA17/23/34 Motor 3A on Ebay update.
    By TommeyReed in forum Motor Drivers & Controllers
    Last Post: 06-03-2012, 06:01 PM
  3. FOR SALE: 4 Axis TB6560 Stepper Motor Driver Board
    By Mad Professor in forum Items For Sale
    Last Post: 04-01-2011, 06:54 PM
  4. eBay TB6560 Stepper Motor Driver Boards
    By irving2008 in forum Motor Drivers & Controllers
    Last Post: 07-04-2010, 04:48 PM
  5. manual for eBay TB6560 Stepper Motor Driver Boards?
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 06-01-2010, 10:37 PM
