I've done more fiddling with the table and found that at 2500mm/min the table is repeating position over 200mm for the x and 150mm for the y better than 0.01mm (in fact pretty consistently within 0.003mm) which I am extremely pleased with. I tested fairly extensively with 10 or 20 repeat cycles.
I am still getting the grunting noises from time to time, so I suppose this is down to the latency of the processor generating the pulses?Last edited by Agathon; 09-07-2017 at 09:08 PM.
09-07-2017 #2
09-07-2017 #3
09-07-2017 #4
Try the attached spreadsheet (I use LibreOffice if you don't have excel)
Just enter the desired spindle speed in cell A4 and it will calculate the inverter frequency and contactor to energise.
That logic needs put into a Brain using Mach3 DRO 169-Cmd SpindleRPM as the desired frequency.
It uses an inverter frequency up to 100 hz and assumes the manual adjuster is set to 1.5 * motor speed, so for the 1400 speed it's set to 2100 RPM then the inverter will take it to 4200 RPMLast edited by EddyCurrent; 09-07-2017 at 09:36 PM.
09-07-2017 #5
09-07-2017 #6
Ignore that last request I worked out how to do it - probably in a very labourious way but none-the-less it worked.
09-07-2017 #7
when I was testing the touchplate setup on my router, I was getting repeatability to within +-0.003mm. Quick back-of-envelope sums showed that this was equivalent to one microstep. Might this be why this magic number is there? Mind you, my backlash is a bit more than that..
09-07-2017 #8
As it happens Neal I've just run some more tests. Prepare to fall asleep! Contrary what the fool in the vid says, the Y does seven cycles!
Despite all the grunting (not mine) the steppers don't appear to be losing steps at 2500mm/min.
Actually, I don't know what the backlash is yet. I would think it was small but I need to set-up a proper test.Last edited by Agathon; 10-07-2017 at 12:10 AM.
10-07-2017 #9
Just measured the back-lash at 0.03mm on each axis. I'm a little surprised by this since I can't push/pull either axis by more than 0.01mm. The motors are coupled to the screws with flexible star-type couplings (see pic) - which are original and in good condition, but I have to say I've always been suspicious of. Now they are robbing me of precious microns!
Seriously though I can live with 0.03mm.
10-07-2017 #10
Toolbox Refurb - New Handle Fittings
By Wal in forum Metalwork Project ShowcaseReplies: 4Last Post: 22-09-2016, 10:26 PM -
CONVERSION: Sx2 plus cnc conversion
By Lewywri89 in forum Conversion Build LogsReplies: 11Last Post: 30-11-2014, 11:36 PM -
RFQ: CNC Myford Conversion
By Jconway651 in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-10-2014, 09:52 AM -
CONVERSION: X2 conversion on a budget!
By craigrobbo in forum Conversion Build LogsReplies: 1Last Post: 30-10-2012, 05:00 PM -
Sieg sx2 conversion kit
By Goldigger in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 24-04-2011, 07:42 PM
