  1. Quote Originally Posted by Agathon View Post
    Thanks. I notice that you have both DC brushless and AC servos on your website - what are the advantages and disadvantages?
    One take DC and the other takes AC, so the AC servo driver has a power supply built in that is rated to the nominal and peak rated current of the driver.
    Also Just because it's a DC servo does not mean its brushed, a DC servo can be brushed or brushless.
    Quote Originally Posted by Gary View Post
    OK, that's a very concise reply, but why buy a DC over and AC and vice versa?
  3. There are a few reasons, but this one normally gives you an indication.
    Ok, lets say you have a machine with 8 axis and each axis needs a servo, that is not too large.
    you can get 8 AC servo motors and driver and you will be paying more because each driver has its own power supply.
    with the DC option, you will have 8 DC servo drivers and a large power supply.
    Also DC servo motors are typically low voltage DC, so the current is higher, so typically the motors dont go too big (under a KW)
    Personally, i would not even consider a DC servo system, unless you know why you need it. AN ac servo system is typically a better option.
    Right, so AC servo drivers aren't typically 240vac SP input then and need a step-down transformer?
  5. No, AC is AC, regardless of the voltage.
    Typically single phase goes up to about 1.5KW
    For a hobby machine, its unlikely you will need anything that big.
    Even a mill like Bridgeport MDI /Interact can use 750W easily.
    OK, so just to be clear. A 400W AC servo motor would typically be coupled to a driver powered by AC at a voltage less than 240v? So is the power supply simply a step-down transformer or is there more to it?
  7. it totally depends on what the bus voltage of the motor is.
    To make it easy, if and when you buy them get a matched pair with cables, or talk directly to the company and get advise on what they suggest for the application.
    Me too. And honestly valuing my time i will not consider separate PSU but a pure plug and play system.
    No, most of the currently available 400w AC servos are 220-240V
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Nice.
  1. CS-LAB AC-servos + SIMdrive
    By blim in forum Stepper & Servo Motors
    Last Post: 20-02-2017, 12:52 PM
  2. Novice- need buying advice
    By davespg996 in forum New Member Introductions
    Last Post: 09-02-2017, 11:12 AM
  3. Advice on Buying a Benchtop CNC
    By Richb in forum Marketplace Discussion
    Last Post: 27-06-2016, 06:43 PM
  4. Mitsubushi Servos
    By Chaz in forum General Electronics
    Last Post: 24-04-2016, 08:08 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
