The stepper ground is temporary as I was still trying to troubleshoot
11-08-2017 #2
11-08-2017 #3
10mm x axis skip. I've now moved the vfd braid shield onto a separate ground than the stepper shielding.
If it happens again, I'll move the spindle motor shield onto th
11-08-2017 #4
Guess what.... all skips happening on parallel moves..... ! Strange
11-08-2017 #5
11-08-2017 #6
I am positive it is not mechanical, if I leave spindle turned off, it does not skip. If I turn spindle on and run job in the air, it jams under no load, and if I try to force it to jam, I can't, so it's 100% electronic interfere
11-08-2017 #7
11-08-2017 #8
It;s the type of Cut the machine is doing when the skipping happens. Its a a sideways X movement with vertical Z at the same time, repeat x 1000
Doesn't seem to skip doing a normal constant Z level manoeuvre....
Now I must be 3.5 hours into this next cut, so far no issues.
11-08-2017 #9
Given the 'zapping' I would be checking you do have a good earth. The normal easy test is one of those plugin testers with LEDs on, but given you're down under, I'm not sure what would be available. It's also worth running the machine at the same time as having the tester plugged into the next nearest socket, just to make sure a good earth remains with things under load.
If you don't have a good earth, then the various filtering capacitors typically found in mains connected electronics (VFDs especially), can cause a voltage build up, which will earth through the nearest thing, which can be the person in contact.
You may need to install a new earth rod, or figure out why you've got a poor earth.
(does Australian power use L,N+E, or a centre tap L,L,N/E? to get 110V and 220V?)Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Help with Problem X axis Stepper Please
By howser37 in forum Gantry/Router Machines & BuildingReplies: 53Last Post: 09-02-2017, 06:31 PM -
Which single stepper for long axis?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 24-05-2015, 08:39 AM -
Connecting BOB one axis to 2 stepper drivers
By Noplace in forum General ElectronicsReplies: 8Last Post: 10-02-2015, 11:56 AM -
Z axis error woes
By HankMcSpank in forum Machine DiscussionReplies: 46Last Post: 18-02-2012, 03:07 PM -
The dreaded task of workshop tidying!
By m_c in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-03-2011, 08:07 PM
