    Quote Originally Posted by lp_felix View Post
    Hi guys, I'm going to build a machine to drill and tapping one part, I'm thinking use a servo for tapping and a regular spindle for drilling. Using a regular servo I can do rigid M3 tapping on 2mm aluminium sheet? Have anyone experience with something similar? Tks
    Enviado de meu Redmi Note 4 usando Tapatalk
    To do rigid tapping you will need a quadrature encoder on the servo and some thing like Linuxcnc to control it.
    Here is a link in Portugal where you can buy the Mesa cards 6i25 with 7i77 bob will do it.
    Are you think of having the spindle and servo on the same gantry?
    You can also do rigid tapping with UCCNC, and with Mach3/4 with the right motion controller.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Hi Ger21, in fact I planing use uccnc. I have a spare Uc300 5lpt (from other unfinished project) I will read the manual.
    Thanks for the tip.
    If it is always the same tap, no pitch change, why not gear vertical displacement to rotation? Drive it with anything you like.
  5. The Following User Says Thank You to Robin Hewitt For This Useful Post:
  6. #5
    Yes, spindle and servo on same gantry.. Ok, I have a lot of questions but i will study quadrature encoder and servo first, and do stupid questions later.. Thank you for the help.
  1. CS-LAB AC-servos + SIMdrive
    By blim in forum Stepper & Servo Motors
    Last Post: 20-02-2017, 12:52 PM
  2. Novice- need buying advice
    By davespg996 in forum New Member Introductions
    Last Post: 09-02-2017, 11:12 AM
  3. Advice on Buying a Benchtop CNC
    By Richb in forum Marketplace Discussion
    Last Post: 27-06-2016, 06:43 PM
  4. Mitsubushi Servos
    By Chaz in forum General Electronics
    Last Post: 24-04-2016, 08:08 PM
  5. Machine Buying advice
    By jrob3rts in forum Marketplace Discussion
    Last Post: 17-09-2010, 04:59 PM
