    Disagree Ger,
    1.
    Why will racking be an issue ?
    A rigid center-driven gantry has perfect balanced push on both sides.
    2.
    There is zero need for not using a fully supported bed like the mechmate.
    3.
    There is zero need for not dropping the drive screw 40 cm, under the bed (or even over it).
    4.
    Ac servos do not need any planetaries - although they might perhaps be used.
    Ac servos will work just like steppers, but 20x better acceleration, much better top speed, 10x more accurate.
    Importantly, servos stop/fault before making major damage.
    The OP looks for a *jobshop* commercial machine.
    I recommended stuff for a *commercial* machine.
    A mechmate cost == 8000$ to build.
    In that context, the servos and 20/25 mm rails cost difference disappear.
    20mm rails are more than large enough for any DIY router.
    If you go with the AC servos, you're going to want to use 10:1 planetary gearboxes, with as little backlash as you can find.
    There are several issues with driving a gantry from the center.
    1) Racking will be an issue, unless you build a very massive structure.
    2) This method requires a table that's suspended at the ends only, which will be less rigid than a fully supported table.
    Using two slaved motors is easier, and works fine.
    You can't have a fully supported bed with a screw under it.
    Fully supported must have a different meaning for you.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Quote Originally Posted by hanermo2 View Post
    Can't see how the geometry of this works. Surely a centre-driven gantry is only balanced if you are cutting a slot up the middle of the bed? Making the gantry stiff enough probably is not a big problem, but the racking loads when cutting at the ends of the gantry are going to put big loads on the guide rails if you want to avoid significant deflection. After all, to be able to cut a 1200mm sheet, you probably want about 1300mm travel, plus width of Z carriage, so the gantry is going to be around 1500mm wide, putting the cutting load point around 700mm from the drive screw. So much easier to drive at both ends, which then allows a better bracing structure for the bed. Slaving two motors really isn't a big deal, after all. If I can do it, anyone can.
    If it's going to cost $8000 you might as well buy something like this
    https://www.sign-in-china.com/produc...CABEgKOHvD_BwE
    Looking at freight shipping to felixstowe it'd be £300 which is very reasonable, then you have import tax and cost of transport from felixstowe maybe cost £6k but it looks a very capable 8*4 router.
    But then you have to spend another $3000 and a few months time to get it usable. :)
    Gerry
    and then it will still probably have a twist in the frame and nothing will be trammed so you will have to take it apart and try and figure out how to fix it and that's before starting on redoing the electronics. I battled with some ones china cnc for 6mths over in aus, in the end I gave up trying to fix it and just accepted it for what it was and that you couldn't really do any of any size with any accuracy. I mean when you see holes drilled like this on the spindle mount what can you expect. Click image for larger version.
    Quote Originally Posted by charlieuk View Post
    They are to stop you assembling it incorrectly
    look how fare off they are fare they are off from the scribe! I'm supried they even hit the right bit of metal they were trying to dril!
    Hi all, thanks for all your input and sorry for not responding sooner, I have been driving back for my holidays.
    So a lot of interesting comments. Which has given me a lot more to think about.
    Going with square rails is definitely a consideration. I did look at this some time ago the longest I need is about 3500mm. Is there a specific grade/ standard that I should be looking for?
    I leaning more towards steppers for the moment purely because I have done a crap load of research into them, cost and the mechmate site has a lot of support. From what I gather servos are better and upgrading the machine later (when the machine is paying for itself) will probably be on the cards.
    With regards to purchasing a Chinese cnc. When I decided I was going to build a CNC It was for a number reasons.
    1 By building it I will more control over the precision.
    2 I would be able to maintain and upgrade the machine myself.
    3 The whole building and commissioning process would stand me good steed in understanding how to operate it.
    4 Cost, during the build and in maintenance during the life span of the machine
    I could be wrong but I don’t see how a Chinese cnc for under £10K could do that.
    I forgot to mention before, on the software front I have been using Sketchup pro for many years, more recently I received a seat and started working with solidworks.
    Again because I have no experience with parametric cad software and I intend to use the cnc for flat panel cabinet work and true 3d stuff. Am I looking to two separate types of software for this and also what cam programs that work well with them?
    I am committed that I will have to spend a lot of time getting up to speed with these programs, I just want to make sure I choose the most applicable. Any thoughts and advice would be great.
    Thank again all for your comments and thoughts.
  1. Planning on a build: how to select a good driver+motor combo?
    By Noplace in forum General Electronics
    Last Post: 17-01-2015, 05:26 PM
  2. BUILD LOG: The Big Red Mechmate in Aus
    By ozspeedway in forum DIY Router Build Logs
    Last Post: 26-09-2014, 12:14 AM
  3. BUILD LOG: Planning and getting things together
    By bobhome in forum DIY Router Build Logs
    Last Post: 20-12-2013, 07:26 PM
  4. BUILD LOG: Planning and build of my "8020" aluminium CNC Router
    By monza in forum DIY Router Build Logs
    Last Post: 06-02-2010, 11:55 PM
  5. BUILD LOG: Building a mechmate here in the u.k
    By kingfisher in forum DIY Router Build Logs
    Last Post: 30-01-2010, 02:13 AM
