    Its just the jogging really im happy to go back to the pc to do the rest, The pc its as close as I can get it but unfortunately just out of arms reach when looking up close, Its quite a large machine. If its likely to work I guess ill just take a punt on one of the wired usb ones. Im still trying to figure out setting up a z zero probe thing.
    many thanks for the advice
    Chaz's Avatar
    Quote Originally Posted by charlieuk View Post
    I recently bought Ger's 2010 screenset. Its only a few 10s of dollars. Get that and use it, makes probing easier and it comes with a dedicated set of screens for probing etc.
    If you are around the West London area I can show you how I use it on my current machine.
  3. The Following User Says Thank You to Chaz For This Useful Post:
    Im rather nervous with anything electronic or computer related as I only have very limited knowledge and its all a bit black magic to me so a little un easy about changing anything if its working ok as is, but I have just had a look at it and maybe one day I will. im still learning the very basics of machining, I just cut a part with a few tool changes but im changing the tool by hand and then sending it to zero and adjusting the z height by just adjusting to tool in the collet which is not great. Im only down near Brighton so not a million miles away , I could really do will learning a lot more!
  5. #4
    Chaz's Avatar
    You are welcome to pop in (UB108TE) and I can show you what I do. Its not perfect but I believe it will probably give you good info to consider / work with.
  1. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  2. Pendant controller
    By alboy in forum General Discussion
    Last Post: 26-10-2016, 10:01 PM
  3. What should a pendant look like?
    By Neale in forum General Electronics
    Last Post: 30-08-2014, 12:02 AM
  4. JOG IT Pendant
    By Leadhead in forum Marketplace Discussion
    Last Post: 12-11-2013, 06:45 PM
  5. CNC Pendant with 100 MPG
    Last Post: 04-03-2009, 07:09 AM
