Page 20 of 27 FirstFirst ... 101819202122 ... LastLast
  1. #191
    There's a thread on MadModder about this controller, one guy has been in contact with the manufacturer and says V2 of it will be out in about a month or so.
    Alex
  2. How is the software corrected for the perpendicularity of the axes?
  3. #193
    Quote Originally Posted by foto-boss View Post
    As i answered you on Youtube, still not. it must be done in a mechanical way, say bumping the gantry towards mechanical end stops and then switching on the motors. I do that everyday on my machine and its not a big deal. 1 min more.
  4. Quote Originally Posted by Boyan Silyavski View Post
    My question does not concern the subordinate axis.
    The question of correcting the perpendicularity of the axes.
    For example, in Mach3, this is solved through formulas.Click image for larger version.
  5. #195
    Ok i see. I did not even know it existed in Mach3.
    Answer is No. But any software can do this. So it could be corrected in CAD.
    if we are talking DIY CNC here, if its correctly constructed that will not be an issue. Epoxy leveling or surfacing. Mounting one rail against straight edge. With the help of same long straight edge and 2 precision squares mounting the second rail. If care is taken straightness and parallelism less than 0.05-0.02mm could be achieved even in a big router, which is absolutely enough. I have mounted 1000x500 machine with even better precision.
    At the end of the day its a cheap controller. But as i said you can skew the drawing in any CAD then send it to CAM and machine.
  6. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
  7. #196
    It's a bodge for wonky machines which shouldn't be necessary, machines should be built square ;-)
  8. All clear. In any case, I already ordered ddscv1.1 4 axis for the experiment.
    Editing in the CAD program is not suitable for a variety of reasons, so this function is in all serious machine control programs, even in an amateur like a mach3. Precise adjustment of the axes perpendicularly incommensurably faster and more accurately done programmatically, especially in those cases where it is already very difficult to do mechanically.
    Of course, not everyone needs this function.
  9. Quote Originally Posted by magicniner View Post
    Well in words, then all the machines are very accurate and the axes are strictly perpendicular ... :)
  10. #199
    I've never had a manual milling machine where X wasn't correctly aligned with Y but I've only had seven.
    Did everyone get lazy with the advent of CNC to the extent we have to pretend it isn't possible to build machines correctly any more?
  11. The accuracy that suits you and is suitable for your tasks, can not arrange another.
  1. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  2. FOR SALE: Galil Motion Controller - PCI DMC 1842 - four axes
    By lateAtNight in forum Items For Sale
    Last Post: 24-06-2014, 03:41 PM
  3. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  4. Advice please! JAF Motion Controller issues!
    By Mark Chard in forum Machine Control Software
    Last Post: 31-01-2014, 05:03 PM
  5. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
