Thanks for replies.
Magicniner- The inverter is original equipment that was built in by Emco and the spindle was working properly before the prolonged storage. so i did not do any commissioning when i powered up the cnc lathe.
Eddycurrent - do you know if the lenze relies on batteries to remember motor parameters? how does the capacitor reforming help and how do i go about doing it?
07-11-2017 #2
08-11-2017 #3
I don't know about the battery but there is information here, for example, about capacitors; https://www.youtube.com/watch?v=HuALonM_1X4
Roughly speaking a VFD goes from AC input, through a recifier to what is called the DC bus and the capacitors there act as a reservoir before the DC is chopped up into a synthesised sine wave of variable frequency.
I've just seen on page 28 of the manual; http://download.lenze.com/TD/E82EV__...__v3-0__EN.pdf
it says; Storage > 2 years: form the DC bus capacitors.
Page 202 of the manual goes on to say;
Stop!
Special commissioning procedure after long−term storage
If controllers are stored for more than two years, the insulation resistance of
the electrolyte may have changed.
Possible consequences:
ƒ During initial switch−on, the DC−bus capacitors and hence the controller are
damaged.
Protective measures:
ƒ Form the DC−bus capacitors prior to commissioning. Instructions can be
found on the Internet (www.Lenze.com).Last edited by EddyCurrent; 08-11-2017 at 02:59 PM.
12-11-2017 #4
Or maybe nobody cares any more ?
13-11-2017 #5
thanks for the info. appreciate you taking time to send them. i had to travel so didn't have time to log in to check forum.
looking at the info, it seems quite daunting a task to to recommission a machine from long storage :-(
Lenze i500 Inverter
By brandon_costa in forum Motor Drivers & ControllersReplies: 2Last Post: 20-04-2017, 10:02 PM -
1.5KW Spindle and Inverter with collet set 4 months old £120
By adamh in forum Classified Ads, Buy, Sell & SwapReplies: 1Last Post: 22-08-2015, 10:53 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
50/60 volt spindle inverter.
By GEOFFREY in forum Spindles & Drive MotorsReplies: 0Last Post: 24-12-2012, 03:58 PM -
FOR SALE: 2.2KW Water Cooled Spindle + Inverter (yes the Chinese one!)
By Bokoshoko in forum Items For SaleReplies: 3Last Post: 06-02-2012, 12:43 PM
