Page 22 of 36 FirstFirst ... 12202122232432 ... LastLast
  1. #211
    No idea what is going on with my Z today. And in general the machine is acting up after working fine for a hour or two.
    Just set my Z on my part, ran the program that worked before (doing the same op on the same part to test repeatability) and it just plunged 20mm down into it.
    It now thinks the machine cords for Z are 20mm lower than they were just set using 2ref all home".
  2. #212
    So I have spent all weekend and this week so far on this problem to no avail.
    Had one guy on Fusion forum take a look but he could only simulate it so did not see the problem.
    I just noticed on the operation I am running now it looked like it dropped a step.
    Wondering if I am taking to much of a DOC or pushing too hard on the feed and it is pulling the bit?
    Over time it would result it multiple height differences which I am sort of seeing but some heights are correct.
    Once this operation is done ill touch off from the top of my stock and see where it thinks it is.
  3. #213
    I have just touched off my part and it is saying it is +1.3mm.
    Visually it looks like the bit is further down than it should be so I think it confirms that it is slipping.
    I am using the correct collette size and it is tight when I insert the bit.
    Not stupid tiht but it grabs onto the bit.
    I am not over cranking the thread when putting it onto my spindle as I don't want to over do it. But it is still quite tight.
    What is my best option here?
  4. #214
    Lives in East Lothian, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    What type of spindle/collet?
    If it's ER, then it sounds like you're not tightening it enough. ER collets have to be tight or bits will pull out. There are torque settings for standard ER collet nuts, but typically it's as tight as you can get it with your hands and standard sized spanners, however that's assuming things are well anchored. On a freely spinning spindle, gauging tightness can be a bit tricky.
  5. #215
    Lives in Plymouth, United Kingdom. Last Activity: 16 Hours Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    It's possible to buy replacement ball-bearing collet closer nuts for ER spindles. Arc Euro stock them, as an example. I use these on a couple of different ER collet spindles in my workshop, including the ER20 spindle on my CNC router, and they make tightening the collet much easier.
  6. #216
    It is the standard Chinese 2.2Kw one you can grab off ebay for a couple hundred.
    ER20.
    Ill try it a lot tighter then.
    Is there anything I can do to the bit or the ER24 collect light rough it up a bit to get some more grip out of it?
    Ill take a look, thanks!
  7. #217
    Just ran the operation again and I think the same thing has happened again.
    Not had a chance to measure yet but it looks like the bit is about 1mm lower than it should be.
    Will report back soon
    [edit]
    Yep, 1.15mm drop on the bit.
    Ordered the "ER20 Collet Nut with Ball Bearing - Type A - M25x1.5 Thread", hopefully that is the right one and works...
    I also went through all my stock with this problem -_-
  8. #218
    Chaz's Avatar
    Quote Originally Posted by JOGARA View Post
    [edit]
    It would be nice if you replied to PMs about the RFQ you posted.
    Thought I replied to everyone. Did I miss you?
    If so sorry. Update on the whole thing, we are going to try and machine them here, if it does not work we will continue looking at quotes.
  10. #220
    Chaz's Avatar
    Yep, didnt get any response. No problem.
    The STLs you provided were out of scale too, they dont translate to workable CAD parts. They can be converted but Fusion refused. Its better (for future) to export to something other than STL if possible (Step / IGES etc).
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. Newbie question re converting my 6040 machine to use a laser
    By GaryWilliams in forum Laser Machines & Building
    Last Post: 19-10-2015, 03:09 PM
  3. 10 / 15mm thick 6061 aluminium alloy sheet ?
    By rnr107 in forum Marketplace Discussion
    Last Post: 14-01-2014, 12:15 AM
  4. FOR SALE: Polypropylene compound
    By Bjh1985 in forum Items For Sale
    Last Post: 08-09-2013, 09:39 AM
  5. NEW MEMBER: Newbie From China
    By jenniferxu in forum New Member Introductions
    Last Post: 04-01-2011, 06:02 PM
