Page 1 of 21 12311 ... LastLast
    got quoted £2080 to supply and weld this table which a abit on the high price tbh :( i know most of you prefer steel due to it being alot cheaper but surely making the table out of aluminium extrusion isn't going to cost me £2080. if it wasn't such a large table i would try myself but i just aint got the confidence on welding such a large frame.
    Looking at video's of people putting aluminium frames together just looks like fun and easy enough to do but then i have no idea on what methods they took to make sure they had fully flat extrusions for the rails to go on. i know on steel i was going to use epoxy resin but what do you do on aluminium?
    sorry for the questions guy's i just need to start cracking on now otherwise i will just keep listening to my partner nagging telling me its just another fantasy isn't it
    No prob with the questions but I might be a good idea to keep them all in one place. ie in the same thread
    noted Clive :)
    I would get another quote on the welding reefy, but it could be that half the price is for lifting and transporting
    well to be fair he has been the only one to actually get back to me with a quote lol, the minute i mention it needs to be perfectly square and properly made they run lol.
    would it be justifiable to use heavy extrusions for a more rigid strong frame? the price difference is huge but dont mind paying for it if its a plus side for the machine.
    90x90 10mm slot light version
    £122.85 18.9kg
    90x90 10mm slot heavy version
    £198.75 31.5kg
    both 3000mm long
    Quote Originally Posted by reefy86 View Post
    £122.85 18.9kg
    £198.75 31.5kg
    both 3000mm long
    In one of your other posts did not you say you would be happy with a 4' x 4' machine!! or are you set on a 8 x 4?
    bigger machines are generally much more difficult to build and thus more expensive.
    Have a read through some of the very good build logs on here as that might help.
    doesn't seam a bad price to me when you consider the time and material costs. There has to be 500+ in materials and if you want it perfect then your going to need to pay for skilled labour. using 90x90 ali its going to be at least that maybe more!
    forgot to mention about that clive, im sticking with the 8x4 because either way it was the width i was having a problem with not length so even if i went 4x4 i would still have the same problem but thats all sorted now and i am sticking with a 8x4.
    Removed.
  2. BUILD LOG: All steel, no welding, 2000x1300x250mm
    By eurikain in forum DIY Router Build Logs
    Last Post: 28-06-2017, 12:51 PM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Steel base
    By D-man in forum Items For Sale
    Last Post: 09-05-2016, 01:22 PM
  5. Redesign...Steel is now Extrusion
    By FlyHighRC in forum Gantry/Router Machines & Building
    Last Post: 30-10-2015, 10:09 PM
