Thread: Tap removal
Page 2 of 2 FirstFirst 12
    Ok after making this for a HTD belt.Click image for larger version.
Name:	Encoder gear wheel.jpg
ID:	23701 upon drilling & tapping for the grub screws the tap broke full depth so I had a go with alum. Click image for larger version.
Name:	Tap removal Alum.jpg
    it took 500g of alum and 12 hours on the induction hob (the dish was on a piece of 3/8 steel plate) in two sessions at just below boiling point and having to keep it topped up with water ever 45min.
    Result tap was dissolved completely but did discolour the aly a bit, I could have made a new one quicker but wanted to try out the procedure. If I had to do it again I would have use a much deep container and suspended the part on a copper wire.
    Your not married, are you!?
    Mine (the wife) complains if I even try to cure dry-film solder mask in the oven.
    Women!
    This -
    https://www.youtube.com/watch?v=bhzbpDgTvXU
    Use a 3L pop bottle to keep it topped up unattended
    Women!
    Ah Yes, You need somebody to keep an eye on it to make sure it was topped up
  5. #15
    Nice post Clive glad it worked out. You might remember me messing about with alum to remove a broken tap without much success. I think keeping it hot must have helped you which I think you advise me at the time (?) but I couldn't get near the hob
    Luckily I don't break taps any more (ahem) . . .
  1. RFQ: EDM tap removal
    By Saracen in forum Projects, Jobs & Requests
    Last Post: 17-07-2015, 10:41 PM
  2. Boxford VMC 260 Z axis removal? Any ideas?
    By Roboteernat in forum Boxford Vertical Mills
    Last Post: 19-03-2015, 07:10 PM
  3. RFQ: Shot blasting or other paint removal
    By craigrobbo in forum Projects, Jobs & Requests
    Last Post: 01-02-2013, 12:21 AM
  4. AM882,s and Mach3 ......plus hair removal !!!
    By Buba b in forum Motor Drivers & Controllers
    Last Post: 26-10-2012, 05:11 PM
  5. Air cooling/SWARF removal
    By m.marino in forum General Discussion
    Last Post: 01-07-2012, 12:39 PM
