Thread: New Member
Like I said before to give us some detailed pics of inside the control box and better more detailed explanation of exactly whats happening and we will get you working.
If you go into the mach3 folder, usually on C: drive named mach3. Look for a file ending (.XML) with the same name as the profile you load ie: MachMill.xml then Zip it up and post here I can load your settings into mach3 and see how it's setup.
Then from the pics might be able to work out whats going wrong.
19-03-2018 #2
19-03-2018 #3
I've downloaded the.xml file and have it on a usb stick.
I've just up loaded it and guess what?
Computer says it is an invalid file.
What a catastrophe.
Where is the nearest skip?
Mach3Mill.zip
20-03-2018 #4
Ok straight away I can see that you only have one Input setup for E-stop so if you have any limit switches or Home switches they won't work.
Limits switches could be wired in series with E-stop but they wouldn't work as true limits or be able to double up as HOME switches.
Also Mach3 is set to Imperial units which I doubt you want to use. This affects Motor tuning and looking at your settings I've got feeling your all messed up.
So let me know if want imperial or metric. Then I'll talk you thru how to setup motor tuning correctly.
