29-03-2018 #19
Bit of an old thread bump, but with regards to changing the tool angle, I can do this in Fusion for creating a cut, and I think I can add manual code for tool changes as well. I am tending towards LinuxCNC for its expandability and the number of axis it can deal with (if I want to add e.g. laser engraver later) - and also the price is right :). Hopefully I can do a macro or other Linuxcnc equivalent to handle the "tool change". Then perhaps I can also add in z and x offsets to position the cutter correctly as part of the macro, although I'm still a little fuzzy on that. Hell am still pretty fuzzy on all of this actually, but I am learning!
Physically the tool change will be like a horizontal tool turret, with say only 3 or 4 actual tools on it (e.g. rough, final cut, and parting), but with the ability to lock at other angles. If done like a proper tool turret I could have e.g. 30 degree increments, but I could probably just make a rotary table with a brake on it and a geared stepper, should work - so long as it is rigid enough, and I'm pretty sure I can figure that out.
Does this all sound reasonable?!Last edited by MRob; 29-03-2018 at 05:10 PM.
Yet Another Noob. Looking for Kit or Guide
By RatherBeMaking in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 09-04-2015, 09:52 AM -
NEW MEMBER: Noob
By Karl CNC Scenex in forum New Member IntroductionsReplies: 7Last Post: 20-12-2012, 11:16 AM -
NEW MEMBER: Hi from a CNC noob, London
By masonman in forum New Member IntroductionsReplies: 1Last Post: 17-09-2010, 09:57 PM -
NEW MEMBER: noob log in...
By flez1966 in forum New Member IntroductionsReplies: 2Last Post: 12-10-2009, 06:33 AM -
NEW MEMBER: Another Noob!
By Jaff in forum New Member IntroductionsReplies: 3Last Post: 16-09-2009, 10:46 PM
