Thread: Drilling holes on cnc
23-05-2018 #2
Ah - I copied link from my creator page - here you go (not that interesting, to be honest..!):
https://youtu.be/uwDesJPd6a0
All the best.
Wal.Last edited by Wal; 23-05-2018 at 11:35 PM.
24-05-2018 #3
Wal, what are you using for coolant and how are you catching it? Would be cool to see a wide shot and overall setup view of your CNC.
24-05-2018 #4
Here's a link to a handful of pics on an old thread. Added a couple of extras since, but the machine itself remains the same...
http://www.mycncuk.com/showthread.php?p=55068
Sent from my HTC One M9 using Tapatalk
24-05-2018 #5
dfox1787,
Perhaps I missed something, but I don't see any reference to the material you want to drill. That is very important in my opinion. The fact that you have ER collet is not a problem, you just need to buy a set of collets since those are not like a drill chuck, you need a number of those. I have ER11 so I can't drill anything larger than 7mm with drill bits, which is OK for my needs, but of course, even I must have a large number of collets. I am drilling holes from 0.3mm up to 6mm with different drill bits, depending on the material I need to drill in, which can be PCB, aluminium or plastic. Of course, wood and similar is also OK. I also don't know why you feel you are limited to 10k rpm. The recommended lowest rpm for high speed 24k rpm spindles is 6k rpm but I have absolutely no problems to go below that as well.
Drilling starts at 2,5 minute mark.
In that clip I am drilling with different, standard (I think Cobalt) spiral drill bits, from 1.5mm to 5mm and in that video the lowest rpm is 5800rpm, but in aluminium I went as low as 3800 rpm also and that caused no issues at all. What is important is to use sharp and good quality bits. I use no liquid cooling at all and have no issues with welding, but if I have to drill many holes I let the bit to cool now and then.
24-05-2018 #6
24-05-2018 #7
I have a set of collets and 2.5mm is one of them. Drilling in aluminium it is important to spot drill first. I normally use a 6mm 90 degree spot drill for that purpose, and after spot drilling (not resetting the machine so that I keep the zero positions) I just change to the right bits and start the drilling. Just make sure the spindle can't start spinning when you are changing bits so that you are safe.
24-05-2018 #8You think that's too expensive? You're not a Model Engineer are you? :D
24-05-2018 #9
Drilling Ø0.2mm holes on aluminium
By hoezap in forum Metalwork DiscussionReplies: 5Last Post: 09-04-2016, 06:28 PM -
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
RFQ: West London, Park Royal, Acton Area. 4 holes CNC drilling in my new Spindle mount & Z
By stuboy in forum Projects, Jobs & RequestsReplies: 2Last Post: 16-08-2013, 06:40 PM -
RFQ: 5 Axis Hole Drilling in Plywood - 1260 holes in 64 boards - help very much needed!
By pjm699 in forum Projects, Jobs & RequestsReplies: 3Last Post: 16-08-2012, 08:50 AM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
