  1. #2
    Hi Jorge,
    To be completely safe you really should use hardware controlled E-stop safety circuit however you don't need to use an expensive Pilz relay, you can use an ordinary relay and create your own latching circuit. Just make sure the Contacts are rated to suit the current your pulling.
    Here's a diagram showing how to do it using standard 4pole 24Vdc relay. The spare contact can be used to inform VFD that E-stop occured so shuts spindle down or to control other relays etc.
    Also included wiring for PNP sensors.
Name:	IP-M Simple E-stop.png
  2. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. Mach3 Showing Emergency Triggered
    By Cube3 in forum Artsoft Mach (3 & 4)
    Last Post: 03-12-2017, 06:59 PM
  3. Long shot - emergency lathing!
    By Rogue in forum General Discussion
    Last Post: 26-06-2015, 01:44 PM
  4. Sieg KX1 & Mach3 won't come out of emergency reset
    By lateAtNight in forum Gantry/Router Machines & Building
    Last Post: 19-06-2015, 06:37 PM
  5. Connect 121 revamp
    By Miller in forum Conect Lathes
    Last Post: 16-10-2014, 05:42 PM
