    I have cnc router have 3axis when I see control unit I see it have 5drivers instead of 3
    3 of them have same thickness and 2 have another thickness
    what is the role of small drivers !?
    Sent from my ASUS_Z00A using Tapatalk
    Chaz's Avatar
    Follow the motor cables to the motor, that will tell you.
    5 drivers could be for dual motors for Y (or X)? Is there a 4th axis? Is the spindle controlled by a drive?
    no spindle have dedicated VFD
    so If I have dual Y
    Can I connect on the same output from interface board!!?
    RichAuto Dsp A15
    Chaz's Avatar
    Quote Originally Posted by alaamomen9 View Post
    so If I have dual Y
    RichAuto Dsp A15
    I dont know, not done any slave connectivity before. Im sure JazzCNC or others will offer some guidance.
  5. The Following User Says Thank You to Chaz For This Useful Post:
  6. #5
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    so If I have dual Y
    What do you mean by "If I have dual Y " you either have or have not!!
    You have not answered Chaz re "follow the motor wires from the drives"
    Pic off the machine might help. more info required
  7. #6
    manufacturer has used dsp0501
    when I see manual of dsp It was support step motor only !!
    so what is corrert manfacturer or manual !!?
  1. WANTED: Omron R88M-U200 or Yaskawa SGM/SGMP-02A Servos
    By Agathon in forum Items Wanted
    Last Post: 20-07-2017, 02:24 PM
  2. Replies: 0
    Last Post: 18-07-2017, 02:53 PM
  3. WANTED: Yaskawa servopack
    By johnsattuk in forum Items Wanted
    Last Post: 20-01-2016, 01:03 AM
  4. Problem with Yaskawa servodrives
    By btxsistemas in forum Stepper & Servo Motors
    Last Post: 17-06-2012, 12:44 AM
