Thread: cnc3040t
  1. #21
    you need 32bit windows 7
    mach3 can not control the printer port if you have 64 bit windows
  2. #22
    just checked its win 7 32 bit
    im to old to learn and to young to die
  3. #23
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by welshkoiman1962 View Post
    This was asked in post #4
  4. #24
    Then it works!
    I'm running Mach3 on Win7 32Bit
    How have you confirmed the functionality of your Parallel Port?
  5. #25
    mach3 is showing its working on pc but its not moving anything on my cnc
  6. #26
    Is your Win7 32 or 64 bit?
    Doesn't matter since he says he is using an UC100.
  7. #27
    Yes but he is not very good at answering questions... anyway, if he is using an UC100, as he said later, then it doesn't matter. So his conclusions are totally wrong, has nothing to do with XP.
  8. #28
    ok here we go I bough uc100 tried it mack3 estop was on and I couldn't turn it off as u know if estop wont reset mach3 wont work to move steppers on cnc so I bought a parallel port card it turns off the reset but still nothing works on the cnc BUT if I connect my old pc with xp on it all the same settings as windows 7 it works fine
  9. #29
    so the original breakout board works with the old XP PC but not the new windows 7 PC
    its possible the W7 PC either not configured correctly or
    has a 3.3V output that is too low for the BOB
    when you tried the uc100
    what state was the green power LED & blue Communication LED ?
    inside of a uc100
    LEDs visible either side of USB connector
Name:	uc100 LEDs visible either side of USB connector.jpg
    may be the UC100 plug in is not installed correctly ??
    John
    Last edited by john swift; 21-07-2018 at 04:52 PM. Reason: add 2nd picture of UC100
  10. #30
    so whats the output on my xp and my uc100 is a bogus one thought I ordered a proper one it was sold as a uc100
  1. Replies: 2
    Last Post: 19-11-2017, 05:25 PM
  2. CNC3040t probe tool
    By wesk18 in forum General Electronics
    Last Post: 04-12-2014, 05:40 PM
  3. CNC3040t control box newbie here!!
    By wesk18 in forum Motor Drivers & Controllers
    Last Post: 03-12-2014, 08:35 PM
