    Hi!
    I’m currently in "PSU build mode".
    My drivers (JMC 2HSS86H) can be run with 24-70V DC or 30-100V AC.
    Whats the pros and cons by running them on AC?
    Would the PSU look the same, with capacitors but without the rectifier?
    I´ve got 4 drivers and 4 motors. 3 Nm Hybrid, 1,8 mH, slaved Y-axis.
    Working plan resulted in components that would give the drivers 48V and a 600-700 W PSU.
    Would it be a mistake running 2 switched PSU´s of 350W each instead of a DIY Thoroidal PSU?
    It’s cheaper but how about ripple and back current?
    /J
    Quote Originally Posted by JW1977 View Post
    Hi!
    /J
    Re the AC input 3-100 you would not use caps just a transformer with a secondary of about 7--80 v
    If you want to go down the DC route then a toroidal power supply is a better choice using a 22-0-22 secondary would give you about 62V DC when rectified with caps.
    But if i choose to go AC there will not be any capacitors handling the back EMF from the motors right?
    The caps are in the drives. You can't put caps on the transformer without the rectifier before them.
    edit
    Are you sure you have this the correct way round
    This is from the manual but im still leaning towards going DC.
    After all, its quite fun building the PSU...
    So yes you had it the wrong way round. I would up the toroidal transformer to 25- 0 - 25 which would give you about 70v dc when rectified . good vid here. https://www.youtube.com/watch?v=4OoQ...zD30sZjtp_VyqY
    Ok, thanks but i don’t get where I’m wrong, could you please explain?
    As i see it i have the choice to run them with AC and a PSU consisting of only a thoridal transformer.
    The other alternative would be DC and a PSU with transformer, rectifer and caps.
    The motors have 1,8 mH inductance so I figured a 48V PSU would be sufficient to get speed and reduce heat and back EMF.
    Heres Another schematic where it says AC or DC as Power supply!?
    Ok when I said you had it wrong I was referring to "My drivers (JMC 2HSS86H) can be run with 24-70V DC or 30-100V AC" you have the DC and AC transposed .
    You indicated that you would be leaning towards DC.
    You can have either a transformer with caps and a rectifier OR just a transformer.
    Forget about the back EMF the caps take care of that ( there are caps in the driver as well) The heat is what you set the current to on the drive.
    If you want speed for wood routing then a higher voltage PS is beneficial. I would go with 70V DC but your choice.
  9. The Following User Says Thank You to Clive S For This Useful Post:
  10. #9
    Ok, got it!
    I´m gonna take your advice regarding the PSU and build a DC one with higher Voltage.
    Thanks!
  11. #10
    Ok, got it!
    Thanks!
    Ok don't worry about asking questions its cheaper than getting it wrong. Check out Joe's vid its a good guide.
    This is a good place for a one stop shop https://www.rapidonline.com
  1. HSS86 and 2HSS86H Closed Loop Drivers
    By zorro in forum Motor Drivers & Controllers
    Last Post: 28-08-2018, 04:04 PM
  2. Jmc motor driver 2hss86h
    By noyloj in forum Motor Drivers & Controllers
    Last Post: 02-01-2017, 08:38 PM
  3. Driver led's
    By Duffman in forum Motor Drivers & Controllers
    Last Post: 16-01-2016, 02:41 PM
  4. Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
    By george uk in forum Motor Drivers & Controllers
    Last Post: 23-06-2014, 08:38 PM
  5. Replies: 1
