Thread: Choosing a high speed spindle
08-10-2018 #2
https://www.ebay.co.uk/itm/2-2KW-WAT...8AAOSw-W5Us1mz
This is the "good" vfdhttp://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
09-10-2018 #3
09-10-2018 #4
Look carefully at the picture of the front panel to see the difference and also below the pic. you will see that you can scroll through the various pics of it and find the one of the inside it should have a double row of terminals with a relay to one side.
You can get them direct from China.Last edited by Clive S; 09-10-2018 at 08:31 AM.
09-10-2018 #5
https://www.aliexpress.com/store/gro...=price_asc&g=y
Make sure it's set for AUS delivery at the top to get accurate prices.
I use alixpress all the time never had an issue.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
10-10-2018 #6
Thanks for that. I've used alLiexpress (CNCUK's old friend Fred Lee) a couple of times and been entirely happy. I found this link to the Huan Yang company's own shop...
https://www.aliexpress.com/item/HUAN...882112769.html
10-10-2018 #7
This was meant to be a reply to Clive's earlier post but doesn't seem to appear in the right place...
Aha!! It's that sort of inside wisdom that makes all the difference.
KitLast edited by Kitwn; 10-10-2018 at 12:40 AM.
High Speed Spindle - Drilling & Mild Steel
By Chaz in forum Spindles & Drive MotorsReplies: 22Last Post: 29-07-2017, 07:09 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
eBay: 300W 12V-48V DC High speed air cooled spindle motor for engraving milling
By Swarfing in forum Items On eBay UKReplies: 0Last Post: 16-06-2013, 01:33 PM -
High speed spindle for Sieg X1
By ecat in forum Spindles & Drive MotorsReplies: 8Last Post: 29-03-2012, 08:56 AM -
High speed spindle
By leadinglights in forum Tool & Tooling TechnologyReplies: 0Last Post: 27-04-2010, 09:23 PM
