  1. #3
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Given an Arduino Uno is being used, I'd guess it's most likely GRBL that's being used.
    First step would be to use a multimeter and check if the Arduino pin is seeing a change in voltage. Given the description, I'd guess the internal pull-up resistor for the pin should be enabled i.e. getting a bit under 5V, or 3.3V if it's a low voltage board, with nothing connected, then when the touch probe wire is connected to ground, it should drop to 0V (it's got to be as near zero as possible).
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. csmio/ip-m z probe
    By charlieuk in forum CS-Lab (CSMIO)
    Last Post: 16-09-2017, 09:49 AM
  2. g31 code probe
    By warwick in forum Programmers Corner
    Last Post: 02-03-2017, 08:54 AM
  3. Edge Probe + tool length probe on same input
    By Noplace in forum General Electronics
    Last Post: 18-06-2016, 11:12 AM
  4. CNC Probe - Tried this one?
    By Davek0974 in forum Machine Discussion
    Last Post: 03-06-2016, 02:58 PM
  5. Probe-it / any users ?
    By dudz in forum CAD & CAM Software
    Last Post: 02-11-2015, 11:51 PM
