    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Everything rings ;-)
    The question is how much is due to the weldment construction, and how much due to the linear rails?
    There's a very good reason why lots of the high end machine builders are still using box ways.
    Aluminium has better vibration damping than steel. A very general rule is, the more springy something is, the more it rings.
    Simple experiment is take a couples bit of steel and aluminium bar, and give them a tap. The steel will ring far more than the aluminium. Even cast iron bar will ring more than aluminium. Which reminds me, only certain grades of iron have self-damping properties.
    This is something I've occasionally looked at, as I have a machine idea bubbling away in my mind, but I think to build it properly, would involve a foundry. But then I come back to linear rails acting like springs, and think would a weldment be just as good, with a lot less expense involved?
    The rails are only passing on the vibration to the structure they are attached to. The box ways are great because there is always a layer of oil between the two sliding metal parts and it is absorbing 20x more vibrations than the linear rails (according to the info in the last link from my first post) therefore less vibration transferred to the structure.
    Only the grey iron is very good at damping vibration. And it is due to the shape of the graphite that forms, the graphite flakes.
    http://www.atlasfdry.com/grayiron-damping.htm
    I've seen no springs in linear rails or blocks :) If you have the rails transmitting all the vibration to the structure it attaches to, then you have do something to kill them in that structure and steel is not good at that.
    Linear rails rely on a couple rows of balls with minimal contact, and the balls/rails deform under load acting like springs. Off course, the big benefit with linear rails, is you can over spec pretty easily to minimise the problem.
    As with everything, it's a case of picking the best compromise for your needs.
    I dug out some damping tables (I've long had an interest in this sort of stuff, being a loudspeaker designer) and we have \mu values of:
    Aluminium 6061: 5 x 10-3
    Mild steel: 0.9...1.4 x 10-3
    Grey cast iron: 30...90 x 10-3
    Oddly some copper manganese alloys have high damping factors, but sadly I don't see much that for sale, hey-ho.
    Thanks Voicecoil!
    So aluminium is considerably better at vibration damping than steel. Good to know.
    I was just reading about Sonoston, the copper-manganese alloy, used for vessels propellers..
  1. BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
    By njhussey in forum DIY Router Build Logs
    Last Post: 13-04-2020, 05:03 PM
  2. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  3. BUILD LOG: Eyeballs and comments sought for noob build
    By danilius in forum DIY Router Build Logs
    Last Post: 02-04-2017, 11:40 PM
  4. Using a metal cutting burr with a router...?
    By noyloj in forum Metalwork Discussion
    Last Post: 10-01-2017, 12:44 AM
  5. BUILD LOG: First Build-Steel Gantry CNC - Comments on design wanted
    By olaff in forum DIY Router Build Logs
    Last Post: 06-12-2015, 08:34 PM
