    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,749. Received thanks 299 times, giving thanks to others 11 times.
    I use an "inverter" that works on the voltage-doubler principle - it was a bit of a bodge by a now-out-of-business company who grafted a voltage-doubler to the front of what is quite a nice ABB 380V VFD but it does mean single-phase 240V in and 400V or so 3-phase output. It works fine until you put a heavy load on it when the effectively half-mains frequency input means that the DC voltage sags too much between cycles and the VFD trips. I've been kicking around the idea of finding a 3KW 240-415V transformer and go back to the original ABB VFD input arrangement - and a cheap transformer has not found its way to my workshop yet - or try one of those Ecogoo 240-380V boxes (I linked to this company in an earlier post on this thread). They seem to deliver a lot of performance for the price, if they work as well as they claim...
    My lathe has a mechanical variable-speed mechanism so I have no experience with dual-speed motors and VFDs. In fact, I run the VFD at 50Hz output, with a switch that drops this to 25Hz for a quick low-speed option.
    Sounds like they missed a trick and only used a half wave voltage doubler and/or got the capacitor sizes too small. The full wave voltage doubler circuit works pretty well if you do the sums for the output power and choose the right size caps, but it does have twice the component count of the simple circuit.
  1. wiring V1000 VFD from a 2.2kw Chinese invertor
    By dek667 in forum Control Hardware & Systems
    Last Post: 10-08-2018, 10:03 AM
  2. What machine is required please
    By Arzo10 in forum Machine Discussion
    Last Post: 06-03-2016, 12:01 AM
  3. WANTED: Off-cut required.
    By Wal in forum Items Wanted
    Last Post: 14-12-2015, 11:09 PM
  4. Replies: 0
    Last Post: 08-07-2014, 03:11 PM
  5. NEW MEMBER: Help required
    By Vespa Mad in forum New Member Introductions
    Last Post: 24-06-2009, 02:06 PM
