  1. its the same idea that was documented here to avoid racking when usiing one leadscrew offset from centre. The neat idea here is to make it the drive mechanism too... and I've not seen that before! The great thing about this is the pulleys at each end run in the same direction and in sync, so this works as a drive mechanism. 15 or 20mm belts can take some punishment, so it could work well....
  2. The Following User Says Thank You to irving2008 For This Useful Post:
  3. ,how do you change autocad drawings into something everyone can see?
    Export as bmp then use Serif PhotoPlus to convert to JPG
  4. The Following User Says Thank You to BillTodd For This Useful Post:
  5. #3
    Quote Originally Posted by BillTodd View Post
    Or install Draftsight as a freebie.
  6. #4
    Quote Originally Posted by boldford View Post
    2 year ago that mate sure he'd have found something better by now.!
  7. #5
    thanks once again irving.
    I use to work on a machine years ago,that worked very similarly but with wire ropes, which pulled a sledge down a passage that feed cattle.
    great what you think of when looking for cheaper alternatives than racks or ballscrews:naughty:
    do you think that the belts would deflect(bounce) to much on travel over 8 ft?
  1. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  2. WANTED: wanted drive belt and pulleys
    By oadamo in forum Items Wanted
    Last Post: 13-05-2011, 09:00 PM
  3. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 08:44 PM
  4. Standard Drive Belt Size ?
    By Lee Roberts in forum Belt Drive, Pulleys & Timing
    Last Post: 19-05-2009, 10:56 AM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
