    250rpm is doable IMHO
    You are probably right. Stepper technology has moved on and I need to adjust my comfort zone.
    My comfort zones are fairly well tuned, I always 'know' what thickness of material to use, what bolt size etc. But obviously I must now consider adjusting my stepper motor zone, possible my feed rate zone to. This will require a degree of experimentation.
    I have had over 1000 rpm on a disc-magnet stepper and a 40 volt driver but that is one whacky stepper motor.
    Here is another idea which i quite like for linear drive, watch the video which shows the machine using chain and belt. I like the idea of keeping the chain/belt stationary and pulling the axis along on it.
    http://www.youtube.com/watch?v=vETkf...mbedded#at=154
    My machine runs the steppers at 1000rpm for rapids and even had it up 1500rpm at one point but was just too fast for the machine. I am using Roy's 5A driver boards and 5A steppers, had to keep the boards cool to get these speeds with a couple of 120mm fans but no problems so far!
    Quote Originally Posted by HiltonSteve View Post
    Aha! You to have a comfort zone :heehee:
    I have the 220 Volt drivers so presumably it should go like the absolute clappers once I get the 48MHz dedicated cpu rattling the driver pins.
    Thinks: Max step rate 40Khz, divide by 1600 steps/rev, 25 rps, 1500 rpm, 10cm/second rapids resolving 2.5 microns
    No, I'm not brave enough either :rofl:
    Seems that i do without even realising..!! :rofl:
  1. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  2. WANTED: wanted drive belt and pulleys
    By oadamo in forum Items Wanted
    Last Post: 13-05-2011, 09:00 PM
  3. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 08:44 PM
  4. Standard Drive Belt Size ?
    By Lee Roberts in forum Belt Drive, Pulleys & Timing
    Last Post: 19-05-2009, 10:56 AM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
