Thread: idea for linear belt drive
22-01-2010 #2
Had a look this morning and last one has sold.
Sorry
Still to find pitch and get pulleys
Peter
22-01-2010 #3
hi peter
i have just bought 2 of the same belt from epay
(thanks to john for posting the link for item on ebay,tried to reply my thanks but his post has now disappeared?!!!)
they were a bargain only £0.99 each,sadly postage was £5.99 each:nope: oh well cant have it both ways.
another step closer to my build.
Tom
22-01-2010 #4
You are probably right. Stepper technology has moved on and I need to adjust my comfort zone.
My comfort zones are fairly well tuned, I always 'know' what thickness of material to use, what bolt size etc. But obviously I must now consider adjusting my stepper motor zone, possible my feed rate zone to. This will require a degree of experimentation.
I have had over 1000 rpm on a disc-magnet stepper and a 40 volt driver but that is one whacky stepper motor.
22-01-2010 #5
Here is another idea which i quite like for linear drive, watch the video which shows the machine using chain and belt. I like the idea of keeping the chain/belt stationary and pulling the axis along on it.
http://www.youtube.com/watch?v=vETkf...mbedded#at=154
My machine runs the steppers at 1000rpm for rapids and even had it up 1500rpm at one point but was just too fast for the machine. I am using Roy's 5A driver boards and 5A steppers, had to keep the boards cool to get these speeds with a couple of 120mm fans but no problems so far!
22-01-2010 #6
Aha! You to have a comfort zone :heehee:
I have the 220 Volt drivers so presumably it should go like the absolute clappers once I get the 48MHz dedicated cpu rattling the driver pins.
Thinks: Max step rate 40Khz, divide by 1600 steps/rev, 25 rps, 1500 rpm, 10cm/second rapids resolving 2.5 microns
No, I'm not brave enough either :rofl:
22-01-2010 #7
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
WANTED: wanted drive belt and pulleys
By oadamo in forum Items WantedReplies: 2Last Post: 13-05-2011, 09:00 PM -
any one know where to get a belt drive convertion for x2
By Scott in forum Sieg Milling MachinesReplies: 15Last Post: 27-09-2010, 08:44 PM -
Standard Drive Belt Size ?
By Lee Roberts in forum Belt Drive, Pulleys & TimingReplies: 2Last Post: 19-05-2009, 10:56 AM -
Re: Standard Drive Belt Size ?
By HS93 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 18-05-2009, 03:30 PM
