Ok, I'm now actually workjing on the bit that needs an 8mm hole - HELP!
So the story so far. I need a backplate for a pickup wider. I eventually take delivery of 100mm length of 60mm dia round aluminium bar - & I cut 35mm off the end (with a hacksaw - I've a bicep like Popeye now) . I then true it up in my 4 jaw ...it took me absolutely ages - top tip, make sure the jaws are inserted the right way for the size of the piece becuase for all the jaws sorta gripped the piece in their original way...and the piece went in ok, the jaws were almost totally out their holder - their threads hadn't sufficient purchase into the chuck, meaning the jaws were locking up as I tried adjusting them)
Anyway, so the first part went well (turning down about two thirds of the overall length down to about 20mm thereby making a flange type of arrangement (aren't engineering forums great - you get to use all sorts of double entendre sort of words
All this left me to do was drill a simple hole through the middle of the workpiece - piece of p!ss me thinks - hah, not at all - AAAAAAARGHH. You'd think it would be easy, but what I got was a hole that was all over the shop - and that was starting with a centre drill.
I removed the centre drill & then put a normal drill - the thing bends flexes like a b1itch (not a double entendre - just a bitch) - am I meant to use a special type of drill ...maybe stubbier, shorter?
So anyway, I stop after drilling in to the piece about 5mm, panic and instead of using a 7.5mm drill , (I need an 8mm hole)...I slap in a 6.5mm drill - it bends about like a bendy thing in Bendy Convention....no worries thinks me - I'll kick this holes backside & play my trump card - my Micro boring bar!
So after making up a shoddy boring bar holder (I'm too tight to buy a proper one), I start using that, thinking it would be a dream/breeze - AAAAAARGH. This things starts flexing a litoo - I've had to abort the mission for this evening on account I'm ready to torch my lathe - but what's the score with boring bars - is there a technique I'm missing?
If I get a chance I'll post a photo later.
23-01-2010 #2
FOR SALE: Denford MIRAC CNC Lathe. Single Phase. Absolutely complete and perfect running order.
By Nick Butler in forum Items For SaleReplies: 19Last Post: 21-08-2013, 11:20 PM -
a perfect 90deg joint - 15mm Alu
By dsc in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 24-02-2013, 01:31 PM -
Not cutting perfect right angles and sticking on Y axis ?
By Fivetide in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 10-12-2012, 09:41 PM -
Increasing timing pulley bore size from 3mm t0 3.175mm
By divdav in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 14-05-2011, 09:45 AM -
help needed drilling bore hole in mxl timing pulley
By geekinesis in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 02-02-2011, 01:07 PM
