Page 1 of 3 123 LastLast
    Hi my name is Chris and I am new to CNC. I don't have an engineering background but I have always been interested in engineering and manufacturing.
    I am bullding a 4' x 2' cnc router moving gantry design. I'm aiming to cut wood plastic and occasionally aluminium. I know I've made some purchasing mistakes such as 5 mm pitch ball screws that means it will run slow but I've decided to live with this. As far as the build goes the mechanics are nearly done and i have purchased three low inductance nema 34 stepper motors for x and y (motors for moving gantry will be slaved). I have a nema 23 for z axis. I'm aiming for direct drive of the ball screws. I have already purchased a CS labs IPM controller. Next task is to decide between Mach 3 or 4 and to buy suitable stepper motor drivers and a power supply.
    Inevitably I would welcome any advice on my build. Thanks in advance ....Chris
  2. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  3. #2
    Welcome Chris!
    If you use toothed belt drive from your steppers to your ball screws you can get the movement speed you want with pulley ratios.
    I don't have a gantry machine, but if I did I'd couple the screws with pulleys and a belt to eliminate any chance of them getting out of step ;-)
  4. The Following 2 Users Say Thank You to magicniner For This Useful Post:
  5. #3
    Welcome Chris!
    I have got it rigged at the minute with a crude belt drive to drive the gantry ball screws (so i can move gantry up and down with a power drill while im building it). I have considered running it from one motor but when i move the timing belt (20mm wide 8mm tooth pitch) manually there seems to be to much resistance. Hence why im thinking of direct drive and slave method. If i do choose the latter im thinking of putting a thinner timing belt at the far ends of the ball screw just to mechanical sync the ball screws in addition to electronically slaving the motors (this would be a safety / gantry allignment consideration).
  6. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  7. #4
    I'm not a model engineer. I am building the machine as a hobby and eventually manufacture some ideas to see if I can sell them as a sideline / hobby.
  8. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  9. #5
    Welcome to the forum! Would love to see some photos of the machine.
    Quote Originally Posted by chillybo View Post
    Ignore that line - its a phrase that appears at the bottom of all his posts (a signature) - Seems to confuse a number of people!
  10. The Following 2 Users Say Thank You to AndyUK For This Useful Post:
  11. #6
    Work area is a bit untidy at the moment
  12. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  13. #7
    Excuses It helps to see pics. Its not a good idea to have a belt joining the two screws and then using two motors . Either 2 motors or 1 motor with one belt over both screws.
  14. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  15. #8
    having difficulty attaching pics bare with me
  16. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  17. #9
    Hope you can see these pictures of my machine that i have attached.
ID:	25665   Click image for larger version.
ID:	25666   Click image for larger version.
ID:	25667   Click image for larger version.
ID:	25668   Click image for larger version.
ID:	25669   Click image for larger version.
  18. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  19. #10
    Its not freestanding yet i'm waiting for some box section steel to arrive.
  20. The Following 2 Users Say Thank You to chillybo For This Useful Post:
  1. FOR SALE: Lots of 1.23Nm and 1.0Nm Nema 23 stepper motors
    By Jonathan in forum Items For Sale
    Last Post: 29-12-2016, 02:19 PM
  2. lots of help needed here
    By terry1956 in forum CAD & CAM Software
    Last Post: 01-08-2016, 12:34 PM
  3. RFQ: Looking for a reliable CNC prototyper in aluminium, for lots and lots of jobs
    By Felix.U in forum Projects, Jobs & Requests
    Last Post: 01-12-2015, 02:00 PM
  4. NEW MEMBER: New Member desperate to learn
    By Mill Grav Newbie in forum New Member Introductions
    Last Post: 24-04-2012, 01:17 PM
  5. NEW MEMBER: lots of questions
    By jsa2001 in forum New Member Introductions
    Last Post: 01-10-2009, 09:09 AM
