Thread: Supported linear rail question.
While it can be done, dont expect to put the rated load though the bearing.
The bearing is open and the case is ally so will bend if too much load is applied, and when this happens it will go all sloppy.Visit Us: www.automationshop.co.uk
05-02-2010 #2
05-02-2010 #3
The supported round rail is designed so the load is directly on top.
I have seen it used in different orientations, but it is not designed for that.
As an example the TBR16 has a max dynamic load of just under 40 KG, but if you mount it on its side this will go right down and would definitely fail with sustained load of 40KG.Visit Us: www.automationshop.co.uk
WANTED: Supported rail. The bigger the better
By r0bsk1 in forum Items WantedReplies: 0Last Post: 08-07-2013, 07:50 PM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
Some thoughts on using supported rail
By Ross77 in forum Rails, Guideways & BearingsReplies: 0Last Post: 29-01-2010, 07:13 PM -
16mm supported rail how many linear bearings
By progomez in forum Rails, Guideways & BearingsReplies: 13Last Post: 15-01-2009, 09:39 PM -
Supported rail or other?
By lateAtNight in forum Rails, Guideways & BearingsReplies: 16Last Post: 14-11-2008, 02:28 PM
