View Poll Results: Which profiles should I use?
Voters
1. You may not vote on this poll
  • 40 series aluminium profiles (80x80 and 80x160)
    0 0%
  • 45 series aluminium profiles (90x90 and 90x180)
    1 100.00%
    In the final analysis, rigidity is the most important thing, so check the figures for the moments of inertia (Ix, Iy) for the different profiles before making your choice. There are also other vendors/manufacturers such as Motedis, Item, Maunsystem, Misumi and KJN in the UK.
  2. As well as Kanya.
    Kanya is not the cheapest, but is the best in the marketplace, with a very wide range of extrusions and excessories.
    Also there is extrusions that are heavy duty as well as the light so if you need more rigidity, use the heavy versions.
    We sell Kanya by the way. ;0)
    https://www.zappautomation.co.uk/mec...sions-236.html
    We also have some Isel extrusion thats on sale as well.
    https://www.zappautomation.co.uk/sto...xtrusions.html
    Quote Originally Posted by Gary View Post
    As well as Kanya.
    I had not heard about Kanya! What makes you say those are the best in the marketplace? Do you ship to Finland? Do you have similar fastener solution as the MiniTec Power-lock fastener available?
  4. One of the first to bring to the market this type of products, swiss-made, and a very large range. yes there are a very large range of connectors, and you will see them in this link.
    https://www.zappautomation.co.uk/mec...ctors-242.html
    yes we ship worldwide, and the website should work out the shipping costs, but if not, just email me directly.
    Thanks for you answer. I checked the moment of inertia and there is indeed a big difference between the 45 series and the 40 series profiles. The 45 series is way more rigid. Since the rigidity of the base is the most important thing, maybe it is a good decision to spend a bit more on the better profiles?
    Quote Originally Posted by NordicCnc View Post
    Absolutely. As aluminium isn't as stiff as steel you need to get clever and use extrusions that make the best use of the material to get a rigid frame.
    Thanks for your help! I will go with the larger/stiffer aluminium extrusions.
  1. cnc crashes when cutting 2D profiles in wood
    By chrisobrien07 in forum Woodwork Discussion
    Last Post: 16-11-2021, 09:38 PM
  2. Rigidity of aluminium profiles and rectangular tube sections....
    By Voicecoil in forum Gantry/Router Machines & Building
    Last Post: 14-10-2018, 01:51 PM
  3. A good supplier in UK for Aluminium profiles
    By suspension in forum Marketplace Discussion
    Last Post: 07-12-2017, 02:46 PM
  4. Milling Continuous Profiles?
    By Tenson in forum Dolphin
    Last Post: 15-02-2012, 04:53 PM
  5. Aluminium Profiles
    By wizer in forum General Discussion
    Last Post: 10-03-2010, 11:41 AM
