Clive, much appreciated, I might well bend your ear. Encoder = shaft encoder I take it?, that was my plan, with one limit switch to avoid crunching the stepper on the cross slide (I foolishly went for a low profile stepper on the rear of a mount plate instead of the jefree front mount and it will impact the handle for the split nut engage lever
08-10-2019 #2
I actually made a 64 slot disc with slot opto sensors. https://photos.app.goo.gl/66KmdtD7TzUziNih7 you have to be able to move the sensors around to get the correct sync
edit: if I was to do it again I might have used a rotary encoder (it would have to be low count with a PP) But its been working for at least 3 - 4 years
https://photos.app.goo.gl/JH1GWVQbhxe6Z6Yo7 This is it simulating an arc that I needed to put on a roller for my belt sanderLast edited by Clive S; 08-10-2019 at 04:33 PM.
08-10-2019 #3
<sorry, tried to post elsewhere>
08-10-2019 #4
Yes sorry to the op
Windows 7 ~ Microsoft relents on shorter Windows 7 support decree
By AndyGuid in forum Computer SoftwareReplies: 4Last Post: 15-08-2016, 03:30 PM -
Machining thin Balsa
By Nthkentman in forum Woodwork DiscussionReplies: 3Last Post: 05-04-2015, 08:37 PM -
RFQ: RFQ: Need some thin aluminium cutting
By stewpid22 in forum Projects, Jobs & RequestsReplies: 0Last Post: 21-09-2012, 01:11 PM -
Step clamp design - Hold down thin or irregular shaped objects while milling!
By Lee Roberts in forum Programmers CornerReplies: 5Last Post: 15-04-2012, 12:36 PM -
Looking for thin plastic? sheet
By irving2008 in forum Machine DiscussionReplies: 19Last Post: 09-09-2010, 12:32 AM
