I was meaning box section aluminium, not steel, I'm aware of the problems with that. The stuff I got was pretty straight, the only error from square was a very slight (0.3mm) but even dip along the middle of the long sides, obviously the die designer didn't get his shrinkage allowance quite right
08-12-2019 #2
That is interesting, if the box is square to its corners then it is much simpler to skim it flat on the mill.I would need to buy a length in order to check it in the mill with a DTI, Aluminium warehouse if out of stock.
I'm still interested in looking into constructing the gantry from all this spare plate I have.
08-12-2019 #3
I got mine from Simmal (you might need to email/ring them as they don't keep everything ont' website), I suspect other places like DoRé Metals & Smiths might have it too.
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
