Page 4 of 5 FirstFirst ... 2345 LastLast
  1. #31
    I think I might have an idea concerning the jog movements. I set frequency at 35000khz in ports n pins page, again, just following the set up, but I woke up this morning and thought I should change it back to 25000khz.
    So I'll try that when I get in from work.
    RC cars
    RC helicopters
    Motorbikes
    Renovating an entire house
    Twatter: @CrazyLThirteen
    Insta: CrazyLThirteen
  2. #32
    I posted earlier but it looks like the forum didn't take it, alas.
    I have sorted the motor cutting out when moving in jog, feedrate was too high. So I'll need to find the setting for that.
    Also, setting my home position. I had a quick play but not got anywhere yet.
    Calibration of scale too, as I mdi'd and it moved way more than I'd asked.
    Still cant get spindle to turn either.
    What can I say? Learning curve.
    RC cars
    RC helicopters
    Motorbikes
  3. #33
    Is the spindle a stepper motor?
  4. #34
    Quote Originally Posted by Crazy L View Post
    Flatten that curve - solve one thing at once.
  5. #35
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    See this post #37 from Jazzcnc
    http://www.mycncuk.com/threads/13225...544#post112544
  6. #36
    Don't mess around with the Kernal frequency going higher than 25K will only stress out the parallel port and cause other troubles.
    You need to take things one step at a time and break the process into little steps. Mach3 won't do anything if the I/O pins are not set correctly so this is the first place to start.
    Start with Safety first and wire in the E-stop if it has one. Find the pins it's connected to and enter pin # in E-stop Input.
    Then start with getting movement, one axis at a time. Which by the sounds you have the correct pins set because got movement.
    The next step is tuning them to move correctly in Motor tuning. The first setting to deal with is "Steps per". This will make it so moves the correct amount. The easiest way is to See the link Clive posted with my reply in another thread.
    The second step is Acceleration and Velocity, Start with low numbers at first and slowly increase one at a time, never both together, and test until the motors Stall. Then back off 25%. If these numbers are too high the Motors will stall(whizzing/humming sound)
    Good start numbers are (If using metric units) Velocity 500 Accel 250. Even the crappiest machines should reach those speeds without stalling motors.
    Leave the Step pulse and Dir pulse = 0 unless you get erratic behavior.
    From here it's up to you where to move onto next. But whichever you choose only ever work on one thing at a time until it works as you expect or desire.
    Just remember that if the Pin # are not set correctly for Input or Output Mach3 won't know anything about it, so even if wired correctly on machine Mach will be oblivious to it.
  7. #37
    Rob, I don't believe the spindle is a stepper motor.
    Doddy, yes, that is my ethos, otherwise it gets confusing. My other hobbies all follow that mantra.
    Clive and Jazz, many thanks, I will check that out, but not right now, because the wife and I are off to the pub for food, it's Christmas eve so the next couple of days will be solid with visits and visiting.
    So while I'm on the subject. I wish you all a good Christmas and hope you have a merry ol time.
    RC cars
    RC helicopters
    Motorbikes
  8. #38
    Hey guys, hope you all had a good Christmas.
    Following your superior knowledge, I got everything working. I need to tweak the axis speeds though as in jog, it's all good, but if I rapid in MDI, they stall, but I now know how to do that.
    I also have X going in reverse. So I have a question: When setting up the steps, when I tell it to move a distance and then it asks me how much it actually moved, should I have told it that moved in minus? I simply said how much it moved and didn't think anything of it at the time.
    I got the spindle going with a bit of thinking. I hadn't enabled an output.
    Anyway, a couple of tweaks here and there and she'll be all ship shape and ready for making stuff once again. I honestly couldn't have done it without the help you guys have given me.
    I've written my settings down too, on paper, so should something ever happen, or I adjust something and need to un-adjust it, I have something to reference.
    Happy new year to you all.
    RC cars
    RC helicopters
    Motorbikes
  9. #39
    Have a look at the active high/low settings for the axis. If they are not out of kilter with the Y and Z then I would just swap either the A+, A- or the B+, B- at the driver for the X.
  10. #40
    If you have the Motor phases wired correctly IE A+ A- B+ B- and the drives wired Correctly IE: Step+ Step - Dir + Dir - then don't switch the active Hi / Lo because it can cause other issues with pulse edge etc depending on how drive is setup.
    The easier way is to go into Homing / Limits and toggle Reversed, this will reverse the axis but not affect Pulse and Dir. You may need to toggle the Homing direction as well if it goes wrong way when homing.
    No doesn't matter. only needs to know distance moved.
    Thats always a good idea but when finished setting up also make a copy of the XML file which will be in Mach3 folder under same name as the profile name. Then if goes down at any time you just reinstall Mach3 copy the saved XML into folder and it will reload with all your settings ready to go.
  1. CNC problems
    By martythunder in forum General Discussion
    Last Post: 15-02-2017, 08:10 PM
  2. Mach3 Problems problems problems.
    By ECCO in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2016, 10:07 AM
  3. tree problems!
    By kingcreaky in forum Woodwork Discussion
    Last Post: 02-06-2014, 12:35 PM
  4. problems since update
    By motoxy in forum General Discussion
    Last Post: 02-11-2012, 06:14 PM
  5. NEW MEMBER: MDF Problems
    By MrWiz73 in forum New Member Introductions
    Last Post: 31-12-2011, 12:39 AM
