JAZZCNC
Last year when I decided I wanted to build a CNC Machine I knee jerked and went for the fasted option to get going, which to me at that time was a chinese kit which comprised the following
2pcs SBR16 - 350mm linear rail
2pcs SBR16 - 1000mm linear rail
2pcs SBR16 - 1500mm linear rail
12pcs SBR16UU block
1pc* SFU1605 - 350mm ballscrew with ball nut* *(BK12/BF12 end machined)
1pc* SFU1605 - 1000mm ballscrew with ball nut*(BK12/BF12 end machined)
2pcs SFU1605- 1500mm ballscrew with ball nut* (BK12/BF12 end machined)
4pcs BK/BF12 Support
4pcs 6.35*10mm coupling
4pcs Nut housing
4 Nema 23 motors
4 cheap Motor Drivers
1 Mach3 Break out Board (Parallel interface) this has now been replaced with a Chinese USB breakout board. The red one in the images attached.
So i still intend to build a ter with this kit to use as a learning tool but will want to build a more quality version in the near future whit bigger motors capable of cutting aluminium. High Speed cutting is not a priority for me
ID:	27014Click image for larger version.
ID:	27015Click image for larger version.
