    Save yourself a lot of trouble and use dedicated controller without PC. for 200eu you have a 4 axis one.
    Which controller would that be?
    Quote Originally Posted by MCmec View Post
    DDCSV cnc controller . Have the earlier version on my machine and still working like a champ. I am tired of saying how much trouble was Mach 3 + Windows. Check on internet there is enough info and videos on Youtube.
    Have not had time last year , so dont know about the latest if any actual changes.
    PS. I see you have purchased already the laptop. Justifying buying computers instead of concentrating on the CNC machine needed. I guess once you finish what you are doing and remember what i said, you will start understanding what i was saying
  3. The Following User Says Thank You to Boyan Silyavski For This Useful Post:
    Boyan, We all have different needs and just because something works for you doesn't mean it works for everyone or that your way is the only way it must be done.!
    For instance, I've got one of the earlier DDCSV which I don't like it one little bit and doesn't suit my needs. I use Mach3 based controllers with a Laptop and I'm happy with it because does what I need. The DDCSV cannot give or do what I need. I need control-software and hardware that is flexible and allows me to jump from machine to machine with just a few clicks. I also like to see a toolpath on the screen and the early version didn't, thou do believe the latest ones do have a basic toolpath viewer.
    I've also used most of the other common hobby CNC controllers/software and to be honest, most of them are very competent with little to choose between them when it comes to operating the machine. Ease of setup of the machine can differ greatly between them, esp if the machine requires advanced features, but this is mostly just a learning curve which comes with any new software and when the machine is set up correctly then you rarely need to worry about it again so no big deal.
    However backup and user base make a huge difference to new users and Mach3 still has a massive user base which is why I use it on machines I build. The fact it's not supported by Artsoft is not a big deal for the routers/mills I build because the current build works just fine and does everything my routers need. Once it's set up this side never needs to be seen by a user.
    What's more important is the fact a new user who is only interested in USING the machine not configuring it. Can go to a forum or youtube and ask a question on how to operate the software or do what he needs to do to get a job done and someone will come back with an answer quickly. Mach3 blows all others away in this respect purely because it's a numbers game.
    Are there better more stable software/hardware controllers out there, HELL YES, but everyone's needs are different and for your average CNC machine any of them will do the job perfectly fine. However the end of the day It's down to the individual user and there needs along with comfort level and MACH3 with its PC based controller offer a nice comforting easily accessible userbase for most new users.
  5. #4
    Are there better more stable software/hardware controllers out there, HELL YES, but everyone's needs are different and for your average CNC machine any of them will do the job perfectly fine. However the end of the day It's down to the individual user and there needs along with comfort level and MACH3 with its PC based controller offer a nice comforting easily accessible user base for most new users.
    I agree with you , especially about the support. Agree also where mach 3 is much more flexible. I even have proper Mach licence that i payed to support them even that i have the cracked Mach3 working perfectly fine on mine machine.
    But people should know the other possibilities that work perfectly fine 100%. There is a text file that you can program load and jump from machine to machine, just FYI as probably you know that. And have talked out people to pay for their licences to support the software.
    But people also should know that mach 3 means a lot of problems like:
    - needs a windows 32 bit computer
    - needs a dedicated computer that you dont use for internet or anything else
    - the moment there is a but or something not working properly one needs to reinstall everything , clean windows and start again. Sometimes even reinstall windows and repeat everything
    - if a computer stops midway due to lack of electricity almost 99% sure the procedure from above should be done or else problems.
    CNC started as a hobby for me, to support my other hobby of musical instruments making. But now i have a small sign company. So IMO if someone is retired and has time to play around-great. But if someone is making money from his machine, then better forget about mach3 and the problems arising with what i said above.
    You remember when i build mine machine, i tried at least a couple of controllers, from Galil to Pokeys, and i have a couple fo good mach3 controls.
    Nothing nearly is good as the cheapest dedicated controller, and i will continue to repeat that. Eliminating PCs with its memory fails, hard disc fails, windows fails, cable connection fails, board connection fails, power supply fails, etc.. is a must for the person who values his time.
    And also i continue to believe that for the 99% of the people on forums who are for hobby in the CNC the DDCSV will do a fine job, for what they use or will use their machines
    I have mine machine in a garage and live near the sea. When it rains and in winter the humidity is 90% or more, in summer in the garage the temp could be even 50C. Almost 10 years in CNC and 6 pc later, 4 failed hard discs later ,many many problems from mach 3, from the time i use the little chino controller i have forgotten what a problem is.
    So let people decide what to use, but at least they should know they have that option. Nothing beats that for 200 euros. Even the shittiest computer is 50 euros with a proper SSD hardisc, mach 3 licence, windows licence, price of controller, price of software/ if not mach 3/ , etc...
    Every machine I've ever built runs a PC and I've had probably 3 fail in over 15yrs, nearly always HD related. Nearly always on Old PC's, that had been running for years. It's a simple and quick re-install from the backup and your working again, so big deal.
    But I agree if it's your lively hood then time is money, but this forum is mostly speaking to hobby users with little to no experience so having a big user base to fall back on is worth the risk of a PC failer every 5 to 10yrs.!
    If you are a business then downtime precautions need to be taken but that said I've got lots of machines used by business's running PCs working 12hr days and again with no issues. The fact you had issues doesn't mean others will have them, maybe you need to look at how you doing things.? It's poor workman that blames his tools.!
  7. #6
    Had a bit of time to look at this today, it looks interesting. Not quite sure this is the way I want to go at this moment but it certainly looks like it could be very useful. I have not looked at all the aspects of the Control, just watched some of the Utube video. It sounds, like you have had quite a lot of experience with CNC machines before obtaining the control so know what you both want and need. It's good that you prompted me to look at this. Without your input I would not know that there are things like this out there.
    Thank you for the post Boyan
    https://www.youtube.com/watch?v=1pN3F04nhZc&t=5s
  8. #7
    Not that i am a big defender on Chinese stuff but as its simple and it works... Moneywise is the cheapest solution also at around 200e. And simplifies connections also.
    Now i definitely understand why someone will want to have 22" touchscreen nicely displaying a software ,DROS, toolpaths and so on mounted in an Inox shiny box with fancy buttons. I have been there.. I remember even a time having transparent door so i could look at the blinking leds on top of that. Maybe its me but with the years i want only simplicity now and 100% reliability. That's why i don't drive Mercedes S classe as before but VW polo if you know what i mean
  1. help connecting a pot to huanyang vfd 2.2
    By edgas10 in forum General Electronics
    Last Post: 14-08-2016, 06:45 PM
  2. Connecting 2.2kw vfd to Mains supply
    By the great waldo in forum Spindles & Drive Motors
    Last Post: 26-05-2016, 09:39 PM
  3. Connecting power supply for 220v
    By Noplace in forum General Electronics
    Last Post: 10-02-2015, 08:34 PM
  4. Connecting VFD
    By andrew583 in forum Spindles & Drive Motors
    Last Post: 19-08-2014, 01:01 AM
  5. connecting stepper driver to PC
    By berkut in forum General Electronics
    Last Post: 10-06-2009, 09:25 PM
