04-02-2020 #10
Well, it depends on how many drives you intend to use now and in the future. Maybe you might add a 4th axis.? In this case, the 750Va allows a little overhead. However, what I didn't mention so as not to confuse the issue is that I've also used 625Va without any issues. But I knew this machine wouldn't need 4th axis because it was fitted with a 4th Axis that was powered from a separate smaller PSU.
If using the Same Voltage then the 5A motor will have lower overall performance than the 4.5A motor. It will have a little more torque lower down the range but the RPM will be lower. This is mostly due to inductance because the higher current motor will have more inductance. It will also create more heat which robs performance.
In this case, half an Amp is neither here or there so wouldn't be a big difference and you'd hardly notice it. Thou any gains would be offset unless something else changed ie: Voltage. Everything comes at a cost.!
In a nutshell, Higher Amp's which often = higher inductance means higher voltage to reach the same speed. This is why often a 4Nm Nema23 will outperform a 4Nm Nema34 motor if using the same volts.
It's also why Large Nm Nema 34, 42 size motors require Very high or better still mains level voltages to allow any reasonable RPM's. All the machines I build that use above 8Nm motors use Mains voltage drives.
People often mistakenly think increasing the current will give more torque, which it does up to a point, but it also increases heat which affects the motor's saturation point which then creates resonance etc so stalls at lower RPM.
It's a complicated formula with several twists depending on motor spec, wiring, etc also with the advent of Digital drives allowing much better performance then Old Vmax (=32*√mH) Formula is even less relevant because the motors can be pushed harder and heat is controlled better along with resonance.
All I can tell you is that if you run the motors at the Rated current with a Voltage 10% lower than the drives Max V you'll be getting the best performance. If you need a little more Torque then increasing the current will provide a little extra but will cost in terms of heat and RPM.
Academic research on CAM CAD software/ Help please
By lorenzo0572 in forum CAD & CAM SoftwareReplies: 3Last Post: 03-05-2014, 11:08 AM
