Suggest you do a search for AC bearings and look at how they visually differ from standard Deep grove bearing. The visual clues when in your hand are the inner and outer races will have a thin edge and a thick edge. The inner race thin side will always face the Outer races thick edge. They will also come apart if you push on them.
Also, do a search on the forum because there's been many people show the BK bearings stripped down and will explain how they need to be assembled correctly.
Edit: Obviously if there is a number on the bearing this will ID the bearing type but often you'll not see this without stripping the BK block down.
10-02-2020 #2
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
wobble / wiggle on ballscrew double row angular contact bearing
By dsc in forum Lead Screws, Nuts & SupportsReplies: 7Last Post: 14-12-2013, 08:35 PM -
Ballscrew Support Bearings - Angular or Self Align or ??
By williamturner1 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 02-10-2010, 02:38 PM -
BUILD LOG: 8020 belt driven 3 axis
By compfranon in forum DIY Router Build LogsReplies: 20Last Post: 30-03-2010, 05:06 PM -
BUILD LOG: Belt driven 3 axis machine
By Swarfing in forum DIY Router Build LogsReplies: 14Last Post: 21-02-2010, 10:46 PM
