    I’ve found Fusion 360 to be a real pain in the ass to learn, I’m a ProE / Creo veteran of 20 years and Fusion baffled me at the start. I’ve watched loads of tutorials on YouTube and it’s starting to make sense - it’s a very different way of thinking than how my brain has been programmed to use CAD. That said, it is a very powerful piece of kit which is perhaps what puts people off if they only want to make simple things. Stick with it mate, it’ll be well worth it!!
    Lives in Plymouth, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Quote Originally Posted by JonnyFive View Post
    Absolutely right - I've run a few "intro to F360" sessions for fellow club members and I reckon the ones that have the biggest problems are the ones who come to it with a "I've done lots of 2D draughting and 2D CAD" approach. They have to go through an unlearn cycle before they can pick up the new ideas! Building a 3D model is not the same as creating 2D engineering drawings, and especially not if you want to get the best out of it.
    As for things going wrong when you're not looking - between my last run of my router and the next "switch on from cold" session (no more than overnight) my machine managed to break a limit switch wire inside a junction box; as there were two switches in series, this seems to have also caused one of those switches to self-destruct. Symptoms were axis moving slowly in wrong direction when homing, which was really weird to see. I no longer believe that a machine won't develop a fault if you only turn your back on it for a little while even while it's switched off!
  1. BUILD LOG: 3 Axis Router
  4. 3 axis cnc/router bed
