on the photo of the breakout board. If you look at the 8 pin chip to the right of the 25 pin connector in the bottom left corner. It doesn't look to be seated in its socket correctly. Should just push in to seat fully. Quite common for chips to work out of sockets over a period of time.
05-05-2020 #2
Hi and big apologies for not coming back earlier, however I had to do urgent house maintenance job which took me the last few days!
I’ve spotted this straight after my first post and pushed in back into its place, thanks!
Well, I should explain a little bit better .. they are blinking when touching +5V terminal as same as previously supplying 5V to stepper motors. Once hardwired, all output LEDs are off.
Doddy, if you have some spare time and willingness to help, I would appreciate! I don’t really have any deadlines, just trying to make some regular progress but please if at any point you will think that something is not right with Bob, let me know and I’ll get a new one as instead of wasting your time on this, I could ask some other questions. Is it worth investing in this type BoB or are there better options in let’s say £100 budget?
In a meantime I’ve sent an email to CNC4PC asking them for some more information about wiring and below is what I received:
‘this is an isolated board, so it has two power terminals. Make sure you are using both. The side that interacts with the PC can be powered with a USB cable. Make sure you put a jumper across the EN and the +5vdc next to it.’
Still don’t explain why all the outputs are inhibited when 5V is wired to PC power terminals. What do you think??
05-05-2020 #3
Happily take a look for you - will PM address - if you find a solution in the meantime that's good.
The response from CNC4PC corroborates the info offered earlier - that all makes sense. Their suggestion of using the PC USB is notionally to maintain the isolation on the BoB - that requires that the PC supply is isolated from the CNC Supply - by no means guaranteed. But doesn't affect the price of fish for this exercise.
The inhibited outputs when wired to the PC power terminals - that's the bit I don't understand and prime for investigation - at this point you've done all according to the book.
Question of BoBs - I like the look of this one - it's a well thought out design, however, I tend to go cheap (£5 BoBs) - if I can understand the interfacing to it (e.g. hooking onto an UC300ETH then I have NO qualms of a £5 BoB.).. whereas parallel connection to a PC I can appreciate the rugged nature of this BoB. Everyone else here will have their own opinion.
New CNC build gantry questions
By Capsuna in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 04-12-2019, 12:59 AM -
BUILD LOG: 1800 x 1500 x 500 work area CNC build log
By marbles in forum DIY Router Build LogsReplies: 9Last Post: 17-10-2018, 01:53 PM -
Beginner MYCNCDIY Mill Build questions
By suraj1793 in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 15-11-2014, 06:28 PM -
A few questions before I start my build
By eclassic in forum General DiscussionReplies: 0Last Post: 11-07-2011, 10:54 PM -
NEW MEMBER: Hi from rainy York - build plans/questions
By bikepete in forum New Member IntroductionsReplies: 13Last Post: 11-10-2009, 07:43 AM
