    I'm after a quote for the 1 off motor mount plate as per the attached drawing.
    Included within the zip file is a Solidworks model and a .dxf file.
    Material either Aluminium or Steel (no specific grade required)
    Will pay via Paypal
    Post to Lancashire, UK
    Required ASAP.
    Any questions drop me a mail.
    Regards,
    Anthony
    Attached Thumbnails Attached Thumbnails Motor Support Plate.PDF   Click image for larger version.
Name:	Motor Support Plate.JPG
    Attached Files Attached Files
    How deep are the countersinks (incidentally M8 cap heads require 13mm).
    What is the tolerance?
    Do you supply the metal?
    Robin
    They look like counterbores to me, not enough detail on the drawing.
    John S -
    Patently age has addled my speech centre :heehee:
    And your typing finger :rofl:
    John S -
    Not M8 counterbores. There to allow for some float on M6.
    I'm after full supply material and machining and delivery.
    Had missed I hadn't dimensioned the counterbores, I will update. There are counterbores on the back also.
    Just updated the drawing with counterbore dimensions, also plate thinkness increased to 12mm
    That's OK I'll still do it out of 10mm because you have plus or minus 2mm tolerance :naughty:
    Not grinding your nuts off but yes the drawing is clear enough, I'll have a look tomorrow and see if I have any plate in, probably be 1/2" though if I have? any good ?
    John S -
    Same here, nearest I have in plate is 8mm but I've got a 4m length of 6" x 1/2" alloy :naughty:
    1/2" would be great, Just a mini skim to ensure its flat. Think my 10mm + or - 2mm was trying to make it easy for people t find plate. Would prefer closer too 12mm. How much then?
  1. RFQ: Need part
    By Buckis in forum Projects, Jobs & Requests
    Last Post: 21-02-2014, 01:21 AM
  2. RFQ: Part required machining
    Last Post: 21-10-2013, 02:46 PM
  3. RFQ: X & Z manufacture and design.
    By D-man in forum Projects, Jobs & Requests
    Last Post: 03-11-2012, 01:39 PM
  4. Sort of stuff I manufacture
    By swarfy in forum Metalwork Project Showcase
    Last Post: 18-12-2010, 06:17 PM
  5. BUILD LOG: Mucky Mikes Marvelously Magnificent Machine Manufacture.
    By Mucky Mike in forum DIY Router Build Logs
    Last Post: 19-04-2009, 02:20 AM
