Thread: London newbie to CNC MACH3
29-05-2020 #1
Hi All,
Would like to learn more on CNC Mach3.
Have a CNC machine but unable to use it due to lack of experience.
Have joined to find mentor based in London that is able to help with Mach3 and CNC set up for basic use.
Also to be apart of the wider and local CNC community to learn more.
29-05-2020 #2
Mach3 or any other control software for that matter is actually very simple in terms of user participation on a basic setup.
Yes, Mach3 and most machine control software are very complex and require exact setup to correctly control the machine but this is not something the machine operator needs to know or care about to cut parts.
After the control software as been set up to control and monitor the machine's functions, which is a one-time setup at the time machine is commissioned, the user only needs to know how to load the G-code file and set work Zero then push cycle start.
If the machine has other functions like automatic tool changer or tool probes, etc then there are a few other functions they will need to know about but still nothing too taxing or heavy. I can teach a complete novice with zero machine or CNC experience to operate and cut parts within 30mins on a basic machine and 1hr with ATC and all the toys.
Now the creation of the G-code is another thing altogether. This requires you to learn CAD and CAM which together is where the steep learning curve comes into play. Unfortunately, this is just something you have to get stuck into and learn by trial and error along with watching tutorials, of which there are many for the popular software like SolidWorks, Fusion 360 or vectric aspire, etc. But sadly some of these are expensive pieces of kit.
I suggest you ask any questions about mach3 here and I'm sure I or others will be able to answer them easily enough.
Regards Cad/Cam then first you need to find a software that suits your pocket and needs then again ask questions etc but in all honesty, the best way to learn I find is to set your self a simple project and try to complete it.
This gives you a goal and makes learning easier, then after you have successfully completed this project increase the complexity and build up your knowledge slowly.
After you have learned mach3 along with Cad/Cam then through experience with trial and error cutting you will learn the feeds n speeds required for each material. Only getting on and cutting can teach you this best so get the basics down and start cutting ASAP.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
NEW MEMBER: Newbie from West London
By Ben92 in forum New Member IntroductionsReplies: 0Last Post: 26-04-2020, 12:37 PM -
NEW MEMBER: London Newbie - Looking to learn about CNC / Milling
By jnash in forum New Member IntroductionsReplies: 0Last Post: 12-05-2015, 04:11 PM -
NEW MEMBER: CNC Newbie from london
By jnash in forum New Member IntroductionsReplies: 0Last Post: 12-05-2015, 04:04 PM -
NEW MEMBER: newbie from london
By neurofen in forum New Member IntroductionsReplies: 1Last Post: 03-02-2011, 02:28 PM -
NEW MEMBER: Newbie from SE London
By ajhughes in forum New Member IntroductionsReplies: 1Last Post: 18-01-2011, 02:07 PM
