Thread: Milling machine conversion
29-05-2020 #6
I looked at converting a small vertical milling machine. Mine was a Sealey model but as far as I can see it was very similar to yours in spec.
https://www.amazon.co.uk/Sealey-SM25.../dp/B000RO681O
I had already fitted ballscrews and steppers to another project and was looking to turn this machine into a dedicated CNC mill. When I stripped the table to look at the leadscrews I came to the conclusion that all was a bit compact to shoehorn ball screws into there. The existing screws were only supported in a single end bearing and the crossheads so unsupported at the outer end . Not sure if that would suffice
I wonder what sort of gear is fitted into the CNC variants of these machines. I think it would be good toget a peek in order to get an Idea what you may wish to replicate.
CONVERSION: Clarke milling machine CNC conversion CMD1225D
By Jonathan in forum Conversion Build LogsReplies: 10Last Post: 06-02-2019, 01:18 PM -
Milling machine CNC conversion - keep hand wheels for manual operation?
By birchy in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 23-10-2016, 08:29 PM -
CNC Build - TEP milling machine conversion
By craynerd in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 06-07-2015, 02:09 AM -
Axminster RF31 Milling Machine CNC conversion
By 1113562 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-03-2010, 12:42 AM -
Chester tools champion 16v milling machine conversion
By NICKMODELMAKER in forum General DiscussionReplies: 3Last Post: 26-02-2010, 09:29 AM
